Morning all!
If you've grown up around cars as we have you'll quickly appreciate and hear stories of owners scraping the bottom of their manifolds (sometimes, manifolds worth over $1000!) on bumps, curbs and tarmac, or having stones hit the underside of the header / oil pan / engine. I can even picture exactly what the manifolds look like - post bump!
Anyhow, another benefit of protecting this area of the car with an under panel is that it stops other foreign debris (water, stones, sticks, small kids) from being flicked up into the engine bar. The Laile panel also has venting to help with assisted, directed cooling, and it smooths airflow under the front of the car, which can help pull the nose down at high speed, remove wandering at high cornering speeds and provide a more stable front end of the car.
Normally we wouldn't promote this item as it's oversized and requires a long wait for containers to arrive, but, we've just shipped with DHL and they handled the size just fine! Yes! (EMS, SAL, Japan Post will not take them because of the dimensions). That means once shipped it's a 2-3 day transit from Japan only and shipping is not hideously bad - from $119 per panel delivered!
The panels start at $315 + Air Freight, ea, to NZ. Most are around $330 to $370 ea, plus air, with only very few exceeding this price, but we can quote individually for you all so let us know your chassis.
You can see all applications currently offered here:
UNDER PANEL
The price is not dependent on numbers ordered and the items ship as soon as each is ready, so there's no need to wait for others to order together!
Mac
mac@fortyone.co.nz
http://www.fortyone.co.nz
Facebook: Here
