Wairau Rd BP no longer ultimate?
I just drove past through newly rebuilt BP on Wairau Rd and looks like it didn't had blue handles...
It still had ultimate sign (although it might have been diesel).
So where on the shore you can get BP Ultimate now?
- MrOizo
- Toyspeed Legend
- Contact:
http://www.bpfinder.co.nz/
It lists Ultimate as being at Wairua. Maybe needs an update.
There's one on Cnr Rosedale & Apollo Rds.
I think they either phasing it out slowly or reducing number of sites with Ultimate 98. I went to BP Herne Bay, half the pumps were 95 & other half were 98. Previously all the pumps had 98.
I think given the current fuel price of 91 + 17 Cents per litre extra you pay for 98, the demand has decreased. I remember the good old days, when it was 9 cents more than 91.
Herne Bay is a posh area, so I can only imagine what would demand be for 98 in other regions.....
- tsoob
- Toyspeed Member
- Contact:
BZG|Bling wrote:Would read thread again.
x2
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
15 Parkway Drive
Mairangi Bay
09 486 5317
Adoom wrote:GDII wrote:Also people probably haven't been told that running 91 in most modern cars is bad for the engine and economy.
Define "modern".
'93 AE100 = ?
I put 91 in it because I never drive it and am financially over extended rather than cheap.
Again, false economy, if you can afford to put 10L of 91 then you can afford to put 8L of 95 and get same mileage.
Here is the checklist:
does it have knock sensor?
does it have c/r above 9:1 (N/A)?
Then most likely it will be more economical on the 95 than 91 including the price difference. Especially if it is JDM vehicle.
While I agree with everything said and exclusively run my cars on 98, there are some exceptions to the high compression = high octane rule..
1zz-fe despite being 10:1 was specifically designed with some advanced 'taper squish' piston/head intended to reduce knock resistance with sub-par fuel, they're officially recommended to run on 91. That's not to say you wouldn't improve mileage with more octane, but in this case it might not actually stack up to savings as the timing retard would not be extreme.
molex wrote:While I agree with everything said and exclusively run my cars on 98, there are some exceptions to the high compression = high octane rule..
As far as I understand the ignition system has enough lee-way to take advantage of the high octane anyway.
For example my wife's 1NZ-FE, on 95 it averages about 9.0-9.5L/100Km around the city, on 98 it averages about 8.0-8.5L/100Km same driving patterns. On highway it is ~6 vs ~7L/100Km. I never put 91 in it so have no idea, what it would do, but I suspect it will scale similar.
Regarding recommended fuel, the export variant have different tune to JDM.
