st215 turbo fwd?
Post Reply
Grrrrrrr!
st215 turbo fwd?
Post by Grrrrrrr! »
Has anyone ever seen a st215 with factory 3sgte and 5spd fwd ( e153)
A guy on another forum is claiming that he has bought several of these but I can not find them listed on toyodiy, and I've never heard of a fwd caldina turbo. Same guy also claims gen4 3sgte rods are good for 400hp...
Jdawg
Re: st215 turbo fwd?
Post by Jdawg »
I have seen a couple of turbo/manual Caldinas go through Turners damaged when I have been looking around for parts. So yes they do exist. They normally go for a little bit more than what I have in the budget tho.
Grrrrrrr!
Post by Grrrrrrr! »
But were they FWD? Plenty of turbo manual 4wd Gt-ts around, but never seen or heard of a FWD one.
Contact:
Post by Malcolm »
Sometimes the simplest answer is the correct one: The guy on the other forum is full of shit.
Grrrrrrr!
Post by Grrrrrrr! »
My thoughts exactly, I can find no such beast in toyodiy, but just checking to make sure, because sourcing a late model low kms e153 with triple cone synchros + lsd would be good, and caldinas are way more common than gen3+ mr2s.
however on the other side of the arguement there are people selling them.. http://www.jdmenginedepot.com/jdm_engine_details/236/Toyota_3S-GTE_Caldina_ST215_4TH_GEN_Engine,_Manual_FWD_Transmission,_Harness,_&_ECU_JDM_3SGTE, and that is not an mr2 gearbox, the linkages and clutch line mark it as setup for FWD. I was wondering if they are the 4wd box with the transfer case removed and a blanking plate installed, but that seems like a lot of work for an engine importer to do.
RS13
Post by RS13 »
Malcolm wrote:Sometimes the simplest answer is the correct one: The guy on the other forum is full of shit.
This. The importer may have just had a FWD box from a late model 3SGE Celica, or it might have come from a converted car. Then again, I have been surprised before.. found out recently that they make the 140kW RunX Z in a 2dr version! Certainly not something I've ever seen in NZ, overseas manufacturers seem to make quite a few "better" versions of the jap imports we get.
thegreatestben
Post by thegreatestben »
I was going to suggest it might be some weird import going by a different name to Caldina.
Plenty of weird toyota's in Japan's fleet that don't appear here.
MAC_HATER
Post by MAC_HATER »
its common for yahoo's to blow the boxes doing mad heli's, and then not being able to find or afford the right replacement parts, and just chucking in a FWD box and removing the AWD parts, but that always leaves behind the likes of the rear AWD hubs and stuff behind, so you know a dodgy conversion when you get underneath it for a nosey
but ive never heard of a factory FWD 3S-GTE ST215 before, like its been said above, the guy could easily be talking arse
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
Contact:
Post by Mr Revhead »
Grrrrrrr! wrote:Has anyone ever seen a st215 with factory 3sgte and 5spd fwd ( e153)
Link us :twisted:
Grrrrrrr!
Post by Grrrrrrr! »
Contact:
Bloody yanks. Ask him to show us one then.
Grrrrrrr!
Post by Grrrrrrr! »
Thought about calling BS, but cbf with butting heads with him again after the gen4 rods are shit debate.. apparently in the US of A gen4 3sgtes don't bend rods. Only chased it up on here since low milage e153s are a rare commodity, and I seem to remember it cost Chelles about $1500 to get hers rebuilt with IIRC, some new bearings but no other new parts.. and was 10? years ago.
Timmo
Post by Timmo »
Presumably these are imported engines from Japan? (i.e. the Caldina wasn't sold new in the USA?) If so, then surely our knowledge of JDM stuff would give a better idea than their (relatively) less exposure to JDM models and options?
Ask him where the engines/trans are coming from in case there was another market which got these odd combos.
Lightweight baby
1991 MX5 Supercharged
Post Reply
