NGK Plug + Lead Combos are below for some common applications. Prices don't vary that much between 4-plug and lead sets, but post up your engine and year (and make, model, chassis if you can) and we'll look up some prices for you. This is a pretty good and cheap way to replace the core spark components of your engine - especially if the engine is old - to avoid fouling issues and / or provide you with a better spark overall.
Just a note - these will mainly come from Japan because a) Fitment is assured with JDM engines, b) The US often does not have the specialist plus for JDM engines. That means it's a tad slower than from the USA, but if possible we'll go via the US to save time if in stock there! So some examples (depending on the generation or year of engine, leads / plugs may or may not be available!)
3SGE
Plugs BKR6EIX-11P $99 delivered
3SGTE $199 delivered
Leads TX116
Plugs BKR6EIX-P
3SFE $179 delivered
Leads TE25
Plugs BKR6EIX-11P
1G-FE
Iridium Max BKR5EIX-11P $109 delivered
1G-GTEU
Leads TX134 $220
1JZGTE
Plugs BKR6EIX-P $155 delivered
2JZGTE $289 delivered
Plugs BKR6EIX-11P
Leads *TE79
2JZGE $289 delivered
Plugs BKR5EIX-11P
Leads TE120
7M-GTEU
Leads TX08 $135 delivered
4AGE ~$278 delivered
Plugs BCPR5EIX-11P
Leads TX02
4AGZE $109 delivered
Leads TE114
Okada Direct Ignition Plugs / Leads
Realistically, the 4/6cyl are from $1140 delivered!
Just FYI, Repco sell just the 4 plugs above for $240! Eek!
Anyhow, ask away and we'll quote. For Toyota the majority of new engines are direct ignition, so it will likely be plugs only quotes!
Fortyone Automotive
http://www.fortyone.co.nz
Facebook: Here
Always read our Terms & Conditions - They really do help!
