after an inspection, wasn't the engine or wheel bearings. Got on the hoist at the local Toyota suspecting (hoping) a bolt or something had flowed off from the axles, but the sound is definitely coming from the gearbox.
Toyota did the install of the LSD & new bearings late last year, since then haven't had any issues. Transmission did make a whirring noise - but I think that's normal for a mechanical clutch plate LSD.
A head serviceman(?) at Toyota suspected it was bearing failure - (input, output or diff) The reason they suspected bearing failure was some soda blasting powder may have still been in the case even though it was thoroughly cleaned by Toyota when the LSD was installed. But to know for sure the box would need to come apart.
Details
96 ST202 Celica with S54-06TRD have done 2,000km's since the LSD was installed
Noise sounds like a clunking mechanical noise, coming from the transmission.
Noise happens when: off torque/accelerator, in or out of gear, coasting in neutral.
Happened suddenly going around a sweeping corner.
No issues changing gears or sounds any worse in any single gear including reverse.
2,000kms on new LSD, TRD FF gear oil and new diff bearings.
It was last week when I went in and put the car on the hoist (I've got the car at my place since) They were going to price up a quote & work out a list of parts they would suggest replacing. I've yet to hear anything from them a week later.
This is a reponse I got on another forum..
That's rotten Luck. Ask your installer how he set the preload on the differential bearings. It's a critical step for bearing longevity. A lot of people ignore it because 8 out of 10 times the original shim is more or less the right thickness. plus it's a royal pain to Assemble, check, take apart, switch shims, reassemble, recheck, take apart again...etc. Maybe you were one of the unlucky 2/10. also ask them how they pressed the differential bearings on. Your supposed to press on the inner race, NOT the outer.... I accidentally crushed a cage on one of mine while pressing it onto the helical and had to buy a replacement. funny thing is there is no obvious visual indication that damage was done, so it's easy to miss something like that.
Plus I highly doubt it's the input or output shaft bearings. Two of them are sealed deep groove and the other two are really beefy non-locating rollers. You would have to do something incredibly stupid to harm them. The diff bearings are the most frail by far.
Whats your thoughts? Toyota incorrectly pressed the bearing in, or didn't have the correct preload. I have a spare shim they took out. Wouldn't have thought there would be much difference between the toyta & trd diff housing requiring a shim be removed?
