3sge beams
Post Reply
dskd
3sge beams
Post by dskd »
anyone turboed one and put it in a gt4 ?
IM NOT GETTING LESS HAIR IM GETTING MORE HEAD
GDII
Re: 3sge beams
Post by GDII »
I don't know of any that have been put in a GT-FOUR. Turbo Altezzas are common enough.
The reason you wouldn't put one in a GT-FOUR is because the GEN 5 blocks sit upright where the GEN 1-4 3SGE and GEN 1-4 3SGTE are lent over quite far. Oil drain issues and other things I'd assume.3
EDIT: Fixed engine generations
1990 SW20 MR2
Previous 1990 EE90 Corolla
dskd
Re: 3sge beams
Post by dskd »
so head swap on to a older block ?
Grrrrrrr!
Re: 3sge beams
Post by Grrrrrrr! »
Which 3sge beams engine are you talking about dskd? Altezza beams engine is gen 5, MR2/celica/Rav4/caldina beams engine is gen 4. The gen4 beams is single vvt-i, and is a slant block, the gen 5 dual vvt-i beams from the Altezza is upright.
Putting the beams heads on the non-beams blocks isn't a bolt on job, oil/coolant passages don't line up, then you also have the fun of crank triggers etc to deal with.
And there is no gen5 3sgte, the st215 caldina got a 4th gen 3sgte, which got different manifold/injectors for the st246w.
dskd
Re: 3sge beams
Post by dskd »
try to end up with a gen5 3sgte for a rally car build
Grrrrrrr!
Re: 3sge beams
Post by Grrrrrrr! »
Seems like a lot of work & $$$ for possibly very small gains to me. At the end its still only a 2L turbo, only thing you have gained is vvt-i, which is probably not going to make that much of a difference on a turbo motor with a correctly sized turbo.
The same money thrown at a turbo upgrade and aftermarket ECU on the gen3 would probably get you more useful gains. Or get a gen4 3sgte and bolt that in with very little work required if the gen3 has gone bang. Just replace the rods and pistons on the gen4 first if you are going to beat on it.
dskd
Re: 3sge beams
Post by dskd »
we are restricted to a 34mm air intake on the turbo so every gain counts and want hp and torque from as low as possible
" Seems like a lot of work & $$$ for possibly very small gains to me "
the describes everything on a race car
dskd
Re: 3sge beams
Post by dskd »
looking to make about 300whp with a power curve like this
http://www.bimmerboost.com/images/impor ... 001_-1.jpg
GDII
Re: 3sge beams
Post by GDII »
If you were thinking the Red Top Celica 3SGE then yes, I've seen a few turboed in MR2s.
1990 SW20 MR2
Re: 3sge beams
Post by strx7 »
in currently building an st205 rally car with a 2.2 5S bottom end with a black top altezza head. PM me if you want to talk about it more, I dont really get on here much these days. I started a build thread but there isn't much on it and it hasn't been updated in a long time.
Shane
Post Reply
