I recently started experiencing boost creep in my GTT Caldina when my boost controller is on. I started noticing it after finding a rather large crack in the dump pipe coming off the turbo.
I've had the dump pipe and some other parts of the exhaust replaced and there are now no leaks, however I still experience boost creep when using the controller. With it turned off and running stock boost, it holds pressure fine.
Any ideas of what could cause this? The controller is a Turbosmart eboost street, I've done a visual inspection and can't find any leaks in the controller's lines.
Cheers in advance!
