98 camry,removing anti hijack from factory alarm
Post Reply
catchafox
Post by catchafox »
Hi everyone, i have a 1998 camry gracia mcv21. And just want to stop the doors from locking once i hit 20kms. Any one know the sequence to disable the anti hijacking of the factory alarm? thanks
Contact:
Re: 98 camry,removing anti hijack from factory alarm
Post by matt dunn »
You need to disconnect the speed signal wire from the central locking ECU.
catchafox
Post by catchafox »
Ok thanks any help or advice on where to get wiring diagrames? Or what colour eires and where the module is located
Contact:
Post by matt dunn »
If you work the lock/unlock switch on the door you may hear the module click under the dash, or some of them it is inside the window master switch.
Possibly a purple and white wire?
Mr_procrastination
Post by Mr_procrastination »
To revive old Post... How did this work out?
Just got a cheap 1999 Camry Gracia wagon, and this too drives me crazy.
All the YouTube sequences did nothing for me :(
([][][]II--LT--II[][][])
Mr_procrastination
Lol me and catchafox joined on the same day...... Brother :D
Post Reply
