flygt4 wrote:usually 102-103 mph , which still isn't that good in itself , but the 1 run i got perfect , with clean changes and no flat spot , i was around 15km faster over the line. unfortunately that run was relighted and I got no time
B1NZ wrote:regardless of weather you relighted or not they usually still give you your time don't they? At least they used to, Has the timing system gotten any better? Do they give you the occasional random times and then sometimes no time at all?
Lith wrote:B1NZ wrote:regardless of weather you relighted or not they usually still give you your time don't they? At least they used to, Has the timing system gotten any better? Do they give you the occasional random times and then sometimes no time at all?
It wasn't even a redlight, from a spectators point of view it looked like while they were staging Jeremy tweaked and just nailed it, hooked gears and went the distance. The starting lights were in the process of resetting, so wouldn't have got anything.
flygt4 wrote:theres really F all time to find your ideal revs for launch.
Distrb wrote:flygt4 wrote:theres really F all time to find your ideal revs for launch.
thats why you stage last, that way it all happens when you're ready
IH8TEC wrote:not really, cause i found the same thing at meremere, i did a bigger burnoutthan the other person so i'd always end up staging second. with no launch controller, i didn't have enough time to come up lightly to the line, get revs up to where i wanted, then pulse it, then look up at the lights and they've always just started, and i wasn't slow either at getting the revs up
was a hassle really, would even cut it fine the way they did it if i had the launch controller working, cause that still needs a second or two to build the boost on the line.
do they get the stage lights, and when he's ready pushes a button for the tree to start?
was frustrating for me thats for sure
indeed they dodo they get the stage lights, and when he's ready pushes a button for the tree to start?
bluemaumau wrote:^ is that 2 4agtes in the same pic (bot truenos(by far the fastest))
if so you guys rock
flygt4 wrote:i got some good vids of me sitting still on the startline while he takes off into the sunset
Return to Wellington / Lower North Island Region
