nov 18th+19th , masterton drags
Postby flygt4 » Mon Nov 20, 2006 4:29 pm
thats quite sexual really :lol:
flygt4
Postby B1NZ » Mon Nov 20, 2006 4:54 pm
flygt4 wrote:usually 102-103 mph , which still isn't that good in itself , but the 1 run i got perfect , with clean changes and no flat spot , i was around 15km faster over the line. unfortunately that run was relighted and I got no time :oops:
regardless of weather you relighted or not they usually still give you your time don't they? At least they used to, Has the timing system gotten any better? Do they give you the occasional random times and then sometimes no time at all?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby flygt4 » Mon Nov 20, 2006 4:59 pm
they changed the system last year or the year before i think. dont often get the random 160mph pass anymore. they did have to reset the timing quite a few times tho, not why why.
i didnt get a slip because the timing tree wasnt actually ready , they had reset it and it cycles through all the lights before its ready. i mistook that for the countdown as the marshal had dropped his arms and i thought it was ready. :oops: :oops: :oops:
flygt4
Postby Lith » Mon Nov 20, 2006 5:00 pm
B1NZ wrote:regardless of weather you relighted or not they usually still give you your time don't they? At least they used to, Has the timing system gotten any better? Do they give you the occasional random times and then sometimes no time at all?
It wasn't even a redlight, from a spectators point of view it looked like while they were staging Jeremy tweaked and just nailed it, hooked gears and went the distance. The starting lights were in the process of resetting, so wouldn't have got anything.
Lith
Postby flygt4 » Mon Nov 20, 2006 6:07 pm
hahaha yep its like being on crack sitting on the start line , doesnt take much to set ya off :lol:
shame coz it was my best run of the day.
flygt4
Postby Crucible » Mon Nov 20, 2006 6:09 pm
So whats the story with those lights? There were two "pre - stage" lamps then two "stage" lamps, do you just move forward till both pre stage lamps light up then stop? what are the "stage" lamps for, do they come on if you moved to far or what?
Most guys seemed to be launching on the last amber from what I could see...
Crucible
Real Life Mechanic
Postby flygt4 » Mon Nov 20, 2006 6:12 pm
2 pre stage , to get you into position ,you just creep up until both are lit up. then once you're both in position it goes down thru the 3 ambers then green.
i think they may have been faster than i remember last year , either that or im getting old :lol: theres really F all time to find your ideal revs for launch.
flygt4
Postby Crucible » Mon Nov 20, 2006 6:22 pm
Thats why I wanted launch control with my new ecu, I mean some of you more experianced guys wouldnt need it, but I couldnt imagine anything worse than trying to get the revs right for launch with some car beside you on the limiter, would make me way nervous.
From what I could make out everyone seemed to launch on last amber before green, when do you get red lighted?? if you launch on the second to last amber??
Crucible
Real Life Mechanic
Postby CAMB01 » Mon Nov 20, 2006 8:16 pm
As soon as you see the last amber light up, go for gold because it has a 0.4 of a second delay till the green lights up, so you shouldnt redlight unless you have lightning fast reactions.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Distrb » Mon Nov 20, 2006 9:41 pm
flygt4 wrote:theres really F all time to find your ideal revs for launch.
thats why you stage last, that way it all happens when you're ready 8)
Distrb
Regular Poster
Postby trueno_20v » Tue Nov 21, 2006 12:32 pm
ADMIN EDIT: signature too large
trueno_20v
Postby bluemaumau » Tue Nov 21, 2006 9:21 pm
^ is that 2 4agtes in the same pic (bot truenos(by far the fastest))
if so you guys rock 8)
Postby IH8TEC » Tue Nov 21, 2006 9:50 pm
not really, cause i found the same thing at meremere, i did a bigger burnout 8) than the other person so i'd always end up staging second. with no launch controller, i didn't have enough time to come up lightly to the line, get revs up to where i wanted, then pulse it, then look up at the lights and they've always just started, and i wasn't slow either at getting the revs up
was a hassle really, would even cut it fine the way they did it if i had the launch controller working, cause that still needs a second or two to build the boost on the line.
do they get the stage lights, and when he's ready pushes a button for the tree to start?
was frustrating for me thats for sure
Postby Distrb » Tue Nov 21, 2006 10:16 pm
IH8TEC wrote:not really, cause i found the same thing at meremere, i did a bigger burnout 8) than the other person so i'd always end up staging second. with no launch controller, i didn't have enough time to come up lightly to the line, get revs up to where i wanted, then pulse it, then look up at the lights and they've always just started, and i wasn't slow either at getting the revs up
You can do it by staging first beam, building your revs to where you want, then, once you can hold your desired rev point, slip your clutch slightly so you break the second beam, then watch the lights, and away you go. You just need to be in control of your nerves and know where your revs are
Yes it is just a teeny bit harder on your clutch whilst you're building boost, but it works well, without using launch control.
Just practice, thats all
(however in saying all of this, last time i was at meremere (toyota v honda drags, they used a single stage beam, which makes things a little trickier)
indeed they do
Distrb
Regular Poster
Postby Pies » Tue Nov 21, 2006 11:36 pm
what times was the maroon mx6 pulling?
Current Rides:
Pies
Postby flygt4 » Wed Nov 22, 2006 6:54 am
bluemaumau wrote:^ is that 2 4agtes in the same pic (bot truenos(by far the fastest))
hahaha yep and the one with 90kw less atw was owning meee :lol: :lol: :lol:
i got some good vids of me sitting still on the startline while he takes off into the sunset :wink:
flygt4
Postby Lith » Wed Nov 22, 2006 10:21 am
Pies wrote:what times was the maroon mx6 pulling?
There was an MX6 there? :wink: Nothing to write home about if I remember. It showed up on a trailer though.
Lith
Postby Tozza » Wed Nov 22, 2006 10:33 am
the funniest thing was watching the mx6 trying to get back onto the Trailer in reverse, as its front wheel drive the wheels kept slipping. Why he didnt just go up front first, i dont know. lol :roll:
Tozza
Postby Distrb » Wed Nov 22, 2006 11:20 am
The guy in the MX6 usually races in Sportsman DYO (or C8 for those regulars). AFAIK he's in the low 15's to high 14's. Have raced him a few times.
and he takes the exhaust off it, which makes it sound very horrid! :?
Distrb
Regular Poster
Postby trueno_20v » Wed Nov 22, 2006 12:07 pm
flygt4 wrote:i got some good vids of me sitting still on the startline while he takes off into the sunset :wink:
when can you post them?? :lol:
trueno_20v
Return to Wellington / Lower North Island Region
