Wtborrow beam setter
Postby Stott69 » Sat May 05, 2012 1:22 pm
Anyone got access to one of those head lamp high checkers? Latest WOF has come back saying my beams are now to low?
Stott69
Postby Dell'Orto » Sat May 05, 2012 2:04 pm
Got a flat wall? Draw a line on it and work to that. The tool is called a beam setter btw :P
Postby Stott69 » Sat May 05, 2012 2:12 pm
Na, no flat walls at home n I had them set last wof cause they were to high.
Stott69
Postby Dell'Orto » Sat May 05, 2012 2:15 pm
You dont want to buy one, they're like $1500+ gst new. Just find a friendly garage and ask them to set them? Wont cost much
Postby matt dunn » Sat May 05, 2012 2:22 pm
Stott69 wrote:Na, no flat walls at home n I had them set last wof cause they were to high.
depending on where you go for a WOF, lots of places just screw them down without setting them, as they usually only fail them if they are too high.
Postby Adoom » Sat May 05, 2012 4:07 pm
I'm sure there will be a flat wall somewhere near your house :roll:
Last time I did it, I think the wof guy said the high beam should be 100mm higher than the headlight for every metre away.
It was ages ago, but I think those were the measurements.
Someone correct me if I'm wrong.
Adoom
Postby matt dunn » Sat May 05, 2012 5:07 pm
Adoom wrote:I'm sure there will be a flat wall somewhere near your house :roll:
doesn't sound right to me.
We set them 0.5 degree down on high beam and 1.5 degrees down for low beam.
(edited as it is degrees not % )
Postby Adoom » Sat May 05, 2012 5:49 pm
We set them 0.5% down on high beam and 1.5% down for low beam.
Maybe it was 100mm lower every 3 metres.... :? Meh, it was years ago.
Adoom
Postby pc » Sat May 05, 2012 5:54 pm
Assuming your beam adjusters work, just tell the WOF guy to set them to where he is happy with... why piss around setting it yourself?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby iOnic » Sat May 05, 2012 6:41 pm
Take it into your local garage and get them to adjust them for you. Cost you $&#$% all (if they even charge you). Or get your WOF man to adjust them or you can do it while it's on the beam setter.
Postby Mr Revhead » Sat May 05, 2012 6:49 pm
pc wrote:Assuming your beam adjusters work, just tell the WOF guy to set them to where he is happy with... why piss around setting it yourself?
Lots of WOF only places won't even put water in your washers to test them let alone use an actual tool to do anything!
Postby holden_fan2005 » Sat May 05, 2012 7:51 pm
That's pretty slack if they don't adjust them.
We go like this:
Roadtest, drive in the door, check beam and adjust if necessary. Saves the time of a recheck and it means the customer can see the road when they drive in the dark :D
holden_fan2005
Postby Mr Revhead » Sat May 05, 2012 7:54 pm
:lol: Who road tests these days?
Postby Dell'Orto » Sat May 05, 2012 7:58 pm
Everyone who isnt VTNZ/has an inground brake tester? Hell I know of a couple of places who until recently still used Tapley meters :lol:
Postby iOnic » Sat May 05, 2012 8:14 pm
I still use a Tapley meter :lol: VTNZ in Palmy have basic tools (screwdrivers, Pliers, Spanners etc) and don't mind adjusting headlights or tightening the odd bolt here and there etc to pass you. It's not really worth their while you coming back for a recheck for something stupid - not like you're paying for it. Any WOF place that won't adjust your headlights is a waste of space - unless your adjusters are broken in which case it's not their problem.
Return to Wellington / Lower North Island Region
