Columbus car clinic?
Postby RedMist » Wed Oct 18, 2006 10:39 pm
CircuitLevin wrote:
RedMist wrote:
chch34 wrote:What makes a good tuner? Whats the reason you would/do recommend a tuner?
A tuner that gets big power?
A tuner that does a tune giving you car slightly less power but very reliable?
A tuner thats tuned lots of big HP cars that belong to rich people?
A tuner that has done lots of cars like ours?
A tuner that everyone else says is good, so he must be?
A tuner that noone says anything bad about?
What makes you people pick one tune shop over another? Everyone seems to take sides when it cones to recommending someone, why?
What makes you believe that optimal power isn't reliable?
Brett tuned my Bunderson well (4age, offroader). However didnt get row one quite correct on overrun (which is very hard to do on a dyno). I was very happy with the way the car ran other than it flooded on overrun. Which Brett could have easily corrected given a chance.
After a rebuild and considerably more headwork I took it to Richard at DCH. The guy did a fantastic job, and I seriously couldnt recommend higher. The car ran perfectly, which isnt easy for a simple LEM 4, with no holes, no overrun issues, no accl issues and a bump to 177.5 bhp at the wheels.
Nick at NZEFI, although I have thrown little work thier way (look out for the rally lancer soonish) would certainly work with. I've spoken with him on many occasions and think that Nick and his team could produce both an install and map worthy of an investment.
chch34 didnt say optimal, he said big power. By definition the optimal "should" be a balance of many things. There is a fuel cut on over run check box in the software :)
Isn't optimal the most favourable or desireable result? It is in the Oxford dictionary. I simply meant a so called Wet tune can be more unreliable than one "on the edge".
Fuel cut on overrun, ummm not on the LEM 4. Perhaps, Brett (CCC), Gary (PAD), Gary (WAR), Richard (DCH) and I all missed that box.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby 4000GT » Wed Oct 18, 2006 10:47 pm
Yup I am sure its in the dictionary, its just that you are putting words into chch34's mouth. He didnt say optimal, he said big power, big difference, big will be in the Oxford dictionary also. If by wet tune you mean rich and suffering borewash, personally I find "too" lean or "too" rich equally undesirable if they cause engine failure.
As far as the over run in the Lem 4. Go to section 8.1.1.1 in the manual. Here is the link to the instruction manuals http://www.linkecu.com/support/dlandswu ... /Downloads have a look for yourself.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby RedMist » Thu Oct 19, 2006 4:26 pm
I'm not putting any words into anyones mouth. I gather your argument is that optimal power isnt big power? As such big power isn't the most favourable or desired result? More than pedantic if you ask me.
In regards to fuel cut on overrun I suggest you look at the manual for the LEM4. ( I have two hard copies and a PDF copy locally if you wish to borrow them) Section 8.1.1.1 is in reference to overrun VACUUM on a map system. As I run 304 degree 415 thou lift cams and have little load differential I run TPS only. As stated I had an issue with row one.
RedMist
Postby 4000GT » Thu Oct 19, 2006 5:21 pm
RedMist wrote:I'm not putting any words into anyones mouth. I gather your argument is that optimal power isnt big power? As such big power isn't the most favourable or desired result? More than pedantic if you ask me.
Thanks for not putting words into anyones mouth while telling me what my argument is and making comments on what you said my argument was. Thats the nice thing about making up someones position for them, its so easy to argue against it. lol Incidently, by definition, optimal anything would be the most favourable outcome. All this is really off topic stuff, if you want to have this discussion (whatever it is), PM me. :)
4000GT
Postby RedMist » Thu Oct 19, 2006 5:48 pm
Thanks for not putting words into anyones mouth while telling me what my argument is an making comments on what you said my argument was. Thats the nice thing about making up someones position for them, its so easy to argue against it. lol Incidently, by definition, optimal anything would be the most favourable outcome. All this is really off topic stuff, if you want to have this discussion (whatever it is), PM me. :)
I fail to understand your reasoning. I was attempting to get an understanding as to why you believed I was putting words into others mouths while you were dictating my stance. You stated
and yet you believe that by me stating
is putting words into your mouth? Sounds awfully dictotorial to me.
If you wish to continue this further I suggest you PM me.
RedMist
Postby 4000GT » Thu Oct 19, 2006 5:51 pm
Ok, since you can drop this, where does he say "optimal power isn't reliable"?
4000GT
Postby RedMist » Thu Oct 19, 2006 5:56 pm
Are you overtly pedantic ? Or truly 12 years old?
RedMist
Postby 4000GT » Thu Oct 19, 2006 6:00 pm
RedMist wrote:Are you overtlly pedantic ? Or truly 12 years old?
Still dont see where he said he believes "optimal power isn't reliable" like you said he did. Now, isn that ummmm putting words in peoples mouths? lol
Just sick of people making positions for others and skewing what they said so they can spew garbage out to make themselves feel more important because they like the sound of their own voice. Thats all.
4000GT
Postby RedMist » Thu Oct 19, 2006 6:10 pm
Isnt that exactly what you are doing?
Dictating to me in regards to my own Link setup?
Attempting to alter my references based on a stupidly pedantic technicality? If you looked at each of the references in an unbiased, open manner then you can surely see the relivance.
I am a computer engineeer of 17 years. Have owned Links since 1999. Currently run two an LEM4 and a EvoLink. Have developed my own data logging and alert software for CE devices, and I'm currently porting it for plamOS.
So do you wish for me to state that every time I post my "garbage"? I suggest you do the same before posting your "garbage".
I likewise am sick of people attacking others based on idiotic pedantic statements.
RedMist
Postby Brick » Thu Oct 19, 2006 8:06 pm
:lol:
Brick
I know Kung Fu
Postby 4000GT » Thu Oct 19, 2006 8:18 pm
RedMist wrote: I like boys
Well fair enough, I wont judge you on making a personal lifestyle choice. More power to you.
PS I love that you feel the need to spew your CV and 177.5WHP car stats every 5th post.
Circuit.
B.Com (hons) M.Com (hons) PhD (in progress)
4000GT
Postby Brick » Thu Oct 19, 2006 8:18 pm
shows your maturity level :P
Brick
I know Kung Fu
Postby chch34 » Thu Oct 19, 2006 8:21 pm
What makes you believe that optimal power isn't reliable? What makes you believe the "rich" people dont choose the same tuner as those who dont have the same financial resourses?
Why do we base selection on personal references?
RedMist wrote:I likewise am sick of people attacking others based on idiotic pedantic statements.
Shlt sorry for posting. I didn't post to start an arguement, I was just interested WHY your average Joe Bloggs would recommend their prefered tuner. Im getting my car tuned next week and wanted to know not only WHO to go to, but WHY.
My car is an '81 Corolla DX with a Link LEMV5 with a Z18et using a T3/T4 and all the supporting mods. With all your experience and knowledge of everything, who would you recommend i get to tune it?
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Postby 4000GT » Thu Oct 19, 2006 8:22 pm
I like to keep it flexible :wink:
4000GT
Postby chch34 » Thu Oct 19, 2006 8:25 pm
Make up your mind man, RedMist has 8)
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Postby 4000GT » Thu Oct 19, 2006 8:29 pm
My advice, go with the tuner you feel understands your needs best. Interview them and get the vibe of what they are about if need be. There are so few tuners in chch you will always find someone that has something bad to say about anyone of them. I have had various cars on the dynos at PAD, RE Sinclair, NZEFI, and CCC. They all did a reasonable job except I developed poblems after PAD's tune and he didnt address the issue. I am sure he does good work and has a decent reputation, my car wasnt suited to his dyno however.
PS I have slick tyres for the next event at Ruapuna! Mwahahahaha cant wait.
4000GT
Postby 4000GT » Thu Oct 19, 2006 8:30 pm
haha good burn.
4000GT
Postby chch34 » Thu Oct 19, 2006 8:35 pm
Yea id already made up my mind, just wanted to hear other peoples opinions :D
I got slicks on mine too 8) Gana be turbo'd before next track day?
Ill follow you, we gotta bit to learn bout these slicks i think... :lol: :lol:
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Postby 4000GT » Thu Oct 19, 2006 9:04 pm
chch34 wrote:Yea id already made up my mind, just wanted to hear other peoples opinions :D
Yeah lets try and organise the group like we did last time. I am a little nervous about my first time on full race slicks after seeing the guy roll last time. ha I wont be turbo'ing it for a while, gotta finish the Supra project first!
4000GT
Postby diss7 » Thu Oct 19, 2006 9:06 pm
REOW
What a whole lot of shit
diss7
Return to Christchurch / Upper South Island Region
