Recommendations for dyno run in Christchurch
Postby matt dunn » Fri Aug 14, 2009 1:14 am
rolling road dyno, lol
Want more torque?
take the 17" wheels off and put the 13" back on it
and see the torque go way up.
Best performance mod you'll ever get !!!!!
To work it out, you need tyre diameter, dyno roller diameter,
and someone way cleverer than me to work it out on a calculator.
Postby Rollux » Fri Aug 14, 2009 10:58 am
BWDOWN wrote:Oh I still love this forum, pity the chch members arent as prominent as what it used to be.
Back to the topic of dyno's please keep us all updated with progress :) Good to see someone else spending some decent coin the right way..
Standard is 141kw@7600rpm, 181Nm@6200rpm (approx) (US is 132kw)
What's interesting as everyone says the ECU cannot be reprogrammed, yet Toyota Australia had to reflash the ECU to up the output on the Sportivo to JDM specs so it would fall into the sports car category and hence have more lenient noise criteria. :?
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby Mr Revhead » Fri Aug 14, 2009 11:37 am
are you sure about that?
there was an ECU replacement done on NZ and AUS new cars that were assembled in South Africa. was probably that. That was a complete ECU replacement, not a reprogramme.
I think I toyotas new genration ECU's you can use factory tools to alter some settings
Postby RS13 » Fri Aug 14, 2009 3:18 pm
Hmm..
BWDOWN wrote:My mates 1600 civic ran 151wkw @ 8600rpm & 376nm @ 5500rpm
As long as the power is correct, torque = hp x 5252 / rpm
151wkw = 205whp
torque = 205 x 5252 / 8600 (peak power rpm)
torque = 125ft/lb, or 169nm.
So if B16A factory is 150nm, then your mate has only made around 20nm, which is a bit more realistic than 376nm!
RS13
Postby Rollux » Fri Aug 14, 2009 9:50 pm
Mr Revhead wrote:are you sure about that?
If you do a search on ZZE123 TSB you get TSB 00207, ecu reflash, and this is the bulletin pertaining to all Toyota vehicles requiring a reprogram
http://www.tundrasolutions.com/forums/a ... 002-07.pdf
Are you sure Warwick that they were physically removed and replaced (did you have to order any back in the day?) or was it just the way it was descibed to customers in laymans terms?
I understand that the techs only download a file that is supplied by Toyota, that their tools don't give access for writing custom tunes etc, but if it's possible to have a new file uploaded by Japan, it's possible to create your own program and upload it with the right software...
Rollux
Postby Mr Revhead » Fri Aug 14, 2009 10:04 pm
it was a recall and the ECU's were replaced
but as i mentioned with the newer generation ECU's more can be done in the way of settings, so maybe it was under that
Postby Rollux » Fri Aug 14, 2009 10:15 pm
Mr Revhead wrote:it was a recall and the ECU's were replaced
Maybe they replaced the stock ones with one that could be reflashed?...
Wouldn't happen to have an old one floating around somewhere by chance?
Rollux
Postby Mr Revhead » Fri Aug 14, 2009 10:32 pm
the official word was that they had the wrong ecu's fitted from factory unfortunately i can't remember how they were wrong
um, no..... i havn't been at toyota for over a year :lol:
and i think the old ECU's were sent back to toyota
Postby d1 mule » Sat Aug 15, 2009 12:13 am
i agree with frost and fivebob 3x factory torque sure.....
im getting my 4agte ae70 tuned end of sept at nzefi will post results up...
d1 mule
Postby BWDOWN » Sat Aug 15, 2009 6:34 am
RS13 wrote:Hmm..
151wkw = 205whp
Thanks
Finally someone on here who knows the calculation
On that basis mines 182Nm at the crank. Isint a 4agte turbo?
B20vtec Allmotor 90% of the way to 170wkw Thanks to 0800 cartune 41.co.nz & Spec Performance
My Profile
BWDOWN
Postby BWDOWN » Sat Aug 15, 2009 6:37 am
matt dunn wrote:rolling road dyno, lol
Want more torque?
*cough*? I dont have 17's or 13's
The jumping to conclusions line is over there >>>>>>>>>>>>>>>>>
My Profile
BWDOWN
Postby fivebob » Sat Aug 15, 2009 11:35 am
BWDOWN wrote:The jumping to conclusions line is over there >>>>>>>>>>>>>>>>>
Actually I think you will find it's up there ^^^^^^^^^^^ in your post :roll: .
Matt was just pointing out, that on a rolling road dyno, if you want to get a better "Torque at the Wheels" figure just use a smaller wheel/tyre.
And I would also add that you can dyno in a lower gear for the same sort of magical performance increase ;)
In other words the torque numbers quoted are a meaningless number, or rather only meaningful if you are comparing two vehicles with exactly the same gear ratio, tyre circumference, and done on the same dyno.
BWDOWN wrote:Finally someone on here who knows the calculation
Don't sell yourself short, that's at peak power (as I pointed out several pages ago). Peak torque will be higher than this, but you'd need to know your HP at 6500rpm to work it out ;)
Postby Mr. Mainstream » Sun Sep 06, 2009 4:55 pm
bit of a late reply but here is my result from that same dyno, to compare.
viewtopic.php?t=71975&highlight=
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby Rollux » Mon Sep 07, 2009 5:41 pm
LOL - You have more power at 2500 rpm than I do at 7500rpm! :lol:
Rollux
Postby Bling » Mon Sep 07, 2009 6:34 pm
Its still a Holden though :lol:
Postby Rollux » Tue Sep 08, 2009 10:57 am
Nothing wrong with that 8)
Rollux
Postby crispy'86 » Tue Sep 08, 2009 10:08 pm
BZG|Bling wrote:Its still a Holden though :lol:
Hey now now Luke :lol: . Still respectable figures from a v6
went well last tim i was in it. not sure if that was before the intake mod
crispy'86
Postby Bling » Tue Sep 08, 2009 11:13 pm
Was just having a dig @ Mr DOCHA, he loves it really :lol:
No need to all get defensive :wink:
Postby dnalunchie » Wed Sep 09, 2009 4:43 pm
BZG|Bling wrote:Was just having a dig @ Mr DOCHA, he loves it really :lol:
buy my car luke you know your mrs will love u for it :P
Current: 90 3sfe Corona
dnalunchie
Postby dnalunchie » Wed Sep 09, 2009 5:22 pm
BZG|Bling wrote:I would actually look at it, if I was after a car, as its a bloody good deal! Just give it to me man, i'll look after it :D
lolz there has been times when i thought about giving it away... all the money I spent but now to see it finished im very happy with her... too bad I cant keep it, spread the word up in your neck of thr woods tho.... I want her to go to a good home.
dnalunchie
Return to Christchurch / Upper South Island Region
