4K-E
4K-E
Postby AE86less » Fri Dec 17, 2010 5:35 pm
Just weighing up options for my KE70 that I've acquired.
My first thought was to have a go at finding a standard 3T for a bit more torque, but I'm enjoying the economy of the 4K. How much improvement does an EFI kit make to a 4K? I've never even seen a 4K-E in person.
Also, this may count as a wanted thread for any bits floating round :) It's not a thread to suggest 4ages or any other such swaps. Looking for simplicity and a degree of period correctness.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby GTTpower » Fri Dec 17, 2010 6:40 pm
I had a chat to Quentin from Club-K when he brought his 4K-E KP60 to the drags, he said fuel economy is massively improved over the carbed version, you get about the same amount of power.
Definitely check out Club-K if you want to know more, good luck finding EFI stuff :lol:
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
Postby Bling » Fri Dec 17, 2010 7:50 pm
So its good for greenies....
Bugger that :lol:
Postby matt dunn » Fri Dec 17, 2010 9:21 pm
I think I can get a almost complete EFI set for a 4K?
Would be worth a bit though.
Let me know if your keen and i'll find out for sure.
matt
Postby Snoozin » Sat Dec 18, 2010 11:13 pm
My 4K-U smoked my flatmates old 4K-E and outdid it on gas, both in KP61 Starlets.
Moral - carbs rule, injection is for new age homos.
Snoozin
Postby rollaholic » Sun Dec 19, 2010 10:25 am
quad carb conversion on the cards for torneo?
Postby metal_sean_head » Sun Dec 19, 2010 10:30 am
So you have definitely ruled out a 4AGE. You could just chuck an old Big Port in there.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby iOnic » Sun Dec 19, 2010 10:41 am
There was a full EFI setup on trademe the other day (may still be on) for a 4K/7K (not sure...memory isn't what it used to be)
Postby RomanV » Sun Dec 19, 2010 10:45 am
iOnic wrote:(not sure...memory isn't what it used to be)
But how do you know it used to be good?
Postby iOnic » Sun Dec 19, 2010 10:45 am
Touche :lol:
Postby Mr Revhead » Sun Dec 19, 2010 12:26 pm
imo, 4k-e because you "felt like it" Would need some tweaking to make it worth while I think.
Along the lines of some bigger injectors (Iirc early Laser ones fit) and maybe an older Link.
In stock form power is not its forte... But will start better in winter :lol:
But seeing as you have a KE70, I say go the 3T. Would make it a much nicer car to drive. And I wouldn't be at all surprised if its cheaper to run. K motors are not economical at all. Unless you compare them to other things from the 70's.
Postby rollaholic » Sun Dec 19, 2010 1:34 pm
yeah i was putting at least as much gas into 4k starlet as i was into 4age ae85
Postby AE86less » Sun Dec 19, 2010 2:01 pm
Sweet. Cheers for the input guys. 3T sounds like a better plan.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby RS13 » Sun Dec 19, 2010 3:19 pm
Mr Revhead wrote:But seeing as you have a KE70, I say go the 3T. Would make it a much nicer car to drive. And I wouldn't be at all surprised if its cheaper to run. K motors are not economical at all.
Lol, I'd beg to differ regarding K economy.. I bought a starlet with a 2K once, had a full tank when I bought it, drove it pretty much daily and didn't need to fill it for a month.. then again, I was a cheap ass and nana'd it everywhere. I think you'll find that they're not that economical when you're thrashing them everywhere trying to keep up with bigger, faster cars.
OP, considered a 2TG? They're period, still reasonably quick and parts are still quite plentiful and reasonable to buy. You can get reasonable power out of them as well.
RS13
Postby Dell'Orto » Sun Dec 19, 2010 6:23 pm
Cost vs benefit, you'll be a long time paying for the EFI setup. Just get side drafts, fcuk economy and enjoy the noise :D
