Turbo/wastegate upgrade = cert
Postby Stott69 » Thu Jun 20, 2013 7:51 pm
I read theres twp brake tests, 3&5 cycles. The higher being expected when the ability to wind up boost exsists. This is where Ill probaly be pinged, think they may handle 3 cycles ok, but 5 may be a push and be told to upgrade.
Stott69
Postby 1I1 » Thu Jun 20, 2013 7:55 pm
Mr Ree wrote:If the brakes were only just coping, Im sure you would be told to upgrade them in some way, shape, or form, as the whole point to a cert is making sure nothing is border line, surely?
E
You'd hope so! :lol:
TRD Clicky >>Here
1I1
Postby Mr Ree » Thu Jun 20, 2013 8:39 pm
Stott69 wrote:I read theres twp brake tests, 3&5 cycles. The higher being expected when the ability to wind up boost exsists. This is where Ill probaly be pinged, think they may handle 3 cycles ok, but 5 may be a push and be told to upgrade.
A simple pad compound change will sort that out, Scott.
wak thud gush!
Mr Ree
Postby Stott69 » Thu Jun 20, 2013 8:49 pm
Ill take you for a drive once its running and you can confirm this. Its a nearly 2 tonne car being stoped by the same brakes as a na jza80, and Im making it posible to increase power by 50%.
Stott69
Postby wde_bdy » Thu Jun 20, 2013 8:54 pm
You guys are confusing the threshold required for certification from standard with subsequent mods after cert. 20% is ONLY a threshold required for cert above a standard vehicle.
If you cert a car with a larger turbo even on a run in tune it will be tested to it's abilities in line with legal driving. Brake test for example is still only done to 100km/h even if your car can do 300km/h. Run in tune or not a reasonable driver should not experience any serious change in vehicle dynamics at road speeds.
Bigger turbo after cert is a re-cert but a retune when certed with a tunable computer is not.
Callum
wde_bdy
Postby Mr Ree » Thu Jun 20, 2013 9:30 pm
Stott69 wrote:Ill take you for a drive once its running and you can confirm this. Its a nearly 2 tonne car being stoped by the same brakes as a na jza80, and Im making it posible to increase power by 50%.
The NA brakes have lots of good pad options, you just need to get something thats rated to a higher temperature than you are running now, and you will be amazed how well they will work.
What pads are you running now, out of interest? And how much meat do they have left on them?
wak thud gush!
Mr Ree
Postby Stott69 » Thu Jun 20, 2013 9:43 pm
Not sure what they are to be hounest. Fronts are mag n turbo specials of some sort, bake are jollyjumpers old pads. Sugested pads? Would sloted discs be of any benifit?
(turning in to a thread hijack)
Stott69
Postby 92mr2paddy » Thu Jun 20, 2013 10:07 pm
got slotted discs for the mrs supra with just some BNT pads and its a hell of a lot better than stock, but still think something more is needed for 300+kw, lol
92mr2paddy
Postby cat007 » Thu Jun 20, 2013 10:27 pm
Are brake upgrades listed on the cert plate?
How about wheel spacers?
Postby Bling » Fri Jun 21, 2013 12:05 am
If you're running cheap and crappy pads, you will certainly limit the performance potential of the brakes.
Postby loudstealthGT-Four » Fri Jun 21, 2013 12:08 am
cat007 wrote:Are brake upgrades listed on the cert plate?
Yip Brakes have a dedicated space for info, spacers are also noted on plate
loudstealthGT-Four
Postby MrOizo » Fri Jun 21, 2013 12:33 am
I have spacers listed on mine (25mm bolt on)
MrOizo
Toyspeed Legend
Postby Stott69 » Fri Jun 28, 2013 11:12 pm
Last few comments on this are interesting. VTNZ wof with no cert
http://www.trademe.co.nz/motors/used-ca ... 483606.htm
Stott69
Postby Mr Ree » Fri Jun 28, 2013 11:58 pm
I read that a few days ago and thought it was odd too.
wak thud gush!
Mr Ree
