side note: if you change the wheels to 205inches wide, with 50%, it makes your top speed go through the roof... I was trying to figure out WTF I had screwed up when it was hitting 963mph in third.
RomanV wrote:Here is an example of what is required.
Car title/user name: MikeMan's 1UZ Starion Project (Estimates)
(Engine info)
Displacement: 4206cc
Engine Location: Front
Type: NA
(at flywheel)Horsepower@RPM ~440HP@7500
(at flywheel)Ft-lbs of torque@RPM ~360lb ft @ 5500rpm
Compression ratio eg. 12:1
Redline RPM: 8200RPM
(drivetrain info)
Gears: 5 Speed
Manual/Auto: manual
Gear ratios (below)
1: 3.285
2: 1.894
3: 1.275
4: 1.00
5: 0.861
6: With that torque why would I need a 6 speed?
Final drive ratio: 3.56
Driving wheels: RWD
(Chassis and body info)
Car weight in kgs: 1350kgs.
front/rear weight distribution: eg. 55/45
Wheelbase in cms: 244cm
Tire size: eg. 265/45-17
Coefficient of drag: 0.38
Overall height in cms: 128cm
Overall width in cms: 175cm
Ground clearance in cms: 12cm.
RomanV wrote:It's probably as much of an accurate gauge as Gran Turismo.
