my mods for ae111
Postby Alex B » Mon Jul 09, 2007 6:23 pm
DJ wrote:Lets not forget that CT20b's will make 450hp :P
I take it your meaning CT26??
EDIT: Fecking debug thingy.
Postby gmacrae » Mon Jul 09, 2007 7:04 pm
slighty_sykotic wrote:Dreaming? lol, i want proof. So that motor cost less than 12k? Meaning I could walk into speedtech and hand over 12k and come out with a 550hp 4age?
Search club4ag forums if you want some proof (I CBF). She was talking about it over there a couple years back (andre's mrs, forget her name).
Because im bored here's some REAL rough figures for yaz, most should be on the high side:
Engine w/ loom - $1000 max
Hone, rings, bearings, gasket set, valves re-seated, metal h/g, longblock assembled - $2000
arp main, rod, head bolts - $500 max?
Good cambelt, tensioner, water pump, new harmonic balancer - $1000
Manifolds (chinese ex, custom in) - $1000 max
turbo - $1000
kelford cams - $600?
i/c + plumbing $1000
shit like oil, filters, thermostat, oil feed/return, rad hose etc - $1000
Link - $1000
Tune - $1000
20hrs@ $50 for assembling - $1000
$12100
This is assuming you drive in/drive out and the workshop is pretty competant. 20hours for removing/installing an engine (not incl tune or block work or plumbing/manifold fab work) is pretty bloody generous - but i'd still say fair given it'd be pretty custom stuff and not completely simple. If you're half decent with a spanner for the removal/install and can tow the car between a fab shop, auto sparky, tune shop and home you'll save a bit.
Im finding it hard to believe so many people are doubting the ability of the ZE! A couple years ago we wouldnt even be having this 'discussion' lol - I think a few too many of you have been ripped off by workshops that just arent very good at what they do, now many of you seem to think nothing can be achieved without blowing rwanda's GDP. Professionalism and genuine expertise are too hard to come by these days, that really pisses me off. A workshop that really knows what they're doing shouldnt have any 'unforseen expenses' - too many people just bend over for this excuse.
Anyway im spent, and a bit boozed, gnite
Gene
gmacrae
Postby Lloyd » Mon Jul 09, 2007 8:33 pm
Gotta love those free fuel pumps, wastegates, cheaper-than-cost turbos, standard used pistons, standard head with no work done etc ;)
And one person working on it from start to finish isn't going to get it done in 2 and a half days, thats just a joke.
Postby Alex B » Mon Jul 09, 2007 8:35 pm
And the workshop that can do it in 2 and a bit days charging 50 bucks an hour :lol:
Postby gmacrae » Mon Jul 09, 2007 11:25 pm
lol, listen to you two, but its ok, you're southerners :lol:
$250 fuel pump and $250 wastegate can surely be covered in my over estimating other things dont you think?
Cheaper than cost turbo? Actually no, $1000 is more than you have to pay for a decent turbo these days (hooray knock-offs)
No of course nobody is going to do it in 2 and a half days from drive in to drive out, there's plenty of pissing around to be done by whoever's organizing everything (ie YOU). But thats what the rest of the labour should come to, yes. Any more for that work and you've been shafted.
gmacrae
Postby Alex B » Tue Jul 10, 2007 12:47 am
Would you trust a cheap knock off turbo on a 12k engine?? You havent mentioned rods and pistons either?? And HRT is from further north than you. :lol:
Postby frost » Tue Jul 10, 2007 3:06 am
um they are proven to work so far, even the chinese greedy knock offs are working well. been talked about many times on toymods and all have had great reviews for such cheap turbos.
i have priced up some HKS parts and they fall into what the list says pritty well and they are genuine HKS parts only big money spender item is the rods and pistons,
Postby AceSniper » Tue Jul 10, 2007 2:20 pm
$400 gze pistons 800 aftermarket
$100 shot peened rods, $750 aftermarket
kelford cams are more than 600 unless you re-grind
AceSniper
Postby postfach » Tue Jul 10, 2007 2:32 pm
Franklin will reprofile cams for $350 + freight + GST, not bad, and they're much closer than Kelford.
postfach
Postby Mr Revhead » Tue Jul 10, 2007 2:36 pm
reprofile isnt new billets though....
kelfords regrind price will be similar
kelfords new billets are about $1000
Postby postfach » Tue Jul 10, 2007 2:38 pm
they also do new billet for $750 +freight and gst
postfach
Postby Mr Revhead » Tue Jul 10, 2007 4:23 pm
each or pair?
Postby postfach » Tue Jul 10, 2007 5:23 pm
i believe its for a pair
postfach
Postby AceSniper » Tue Jul 10, 2007 7:18 pm
think were talking 16v here?
but franklin billets for 20v are about 50-60$ more than kelford
rember a "re profile" you will have to spend more on custom shims
AceSniper
Postby frost » Tue Jul 10, 2007 8:09 pm
intake and exhaust HKS billets 272 8.1mm $820 pair
HKS step 2/3 springs $199
HKS cam gears $405 pair
HKS strengthened timming belt $198
HKS bead type head gasket 1.6mm $195
total 1817 +- $50 for exchange rate flux
all landed at your door
thats the head parts. no f@king around with recaps,profiles, shim under bucket. they have been proven over and over again and still people are trying to reinvent the wheel.
shamless plug: im trying to get a group buy on some HKS stuff if any one is intrested look in the for sale section.
Postby AceSniper » Tue Jul 10, 2007 9:21 pm
hks dont make 20v cams or springs... or gears
:roll: :lol:
AceSniper
Postby frost » Tue Jul 10, 2007 10:25 pm
yea they are priced up for the 4agze.
ill get onto some 20v stuff later its not much difference between the two prices from what i have seen. rs hamada and big corner have alot of 20v stuff.
Postby Mr Revhead » Tue Jul 10, 2007 10:41 pm
:lol: $200 for a cambelt
the advantage with local cam makers, is you can specify EXACTLY what you want. sometimes ppl like HKS dont cater for your exact needs
Postby rollaholic » Tue Jul 10, 2007 11:27 pm
something tells me the OP is not in a position to say exactly what he wants :P
Postby frost » Tue Jul 10, 2007 11:36 pm
the cam belt has been designed so it can be taken off and on alot more times then normal when tuning or modifying or changing parts, its just an option i wanted to put in the mix so
edit:bad day
