Mr Revhead wrote:run it around a test track for 300 hours full throttle then ill be impressed
RS13 wrote:snwtoy wrote:Are you guys sure? 300 Hours is a LOOONG time, even for no load.
How long do you think your engine would last if you set it to 6000rpm and just lef it?
Its' ridiculous, and as RomanV said, to impress the non-car oriented public.
It wouldn't be very good advertising if it spat a rod after an hour or two, even if it did, they wouldn't show it. Its' neither here nor there, I would be more impressed by Hyundai announcing that they were reducing emissions, and coming up with alternative-fuel engines, not running a V6 for a couple of weeks, wasting thousands of litres of fuel, and producing several tonnes of carbon monoxide, just to attempt to prove that their engines are reliable!
Idiots.
Adamal wrote:Aww Bae, you jus come up to a corner, and smack it back in second gear, and bounce it off da red line and turn bro! Then you stick your arm out the window and go "CHUR BAE!!!"
ke2nv wrote:its a @#%&@ good piece of advertising though, and its done what hyundai wanted it to do.....make people talk about it.
big_boy wrote:
also i wana see a 3 or 4K do this test as i would reckon you would get at least that & it would only cost you about 150L in gas to do
