300 hours at redline..
Postby strx7 » Mon Apr 23, 2007 9:53 am
most 1G-E's will sit at 7-8000rpm on the rev limiter for 15-20 mins with no water and no air flow before they call it quits
Postby Mr Revhead » Mon Apr 23, 2007 11:55 am
run it around a test track for 300 hours full throttle then ill be impressed 8)
Postby fivebob » Mon Apr 23, 2007 12:55 pm
Low redline, no load, no varying RPM, constant engine temp, even the cheapest crap engine should be able to do that.
Not at all impressive if you know anything about engines, though I'm sure Joe Public will be impressed, and afterall that's what the ad is designed to do, not may petrolheads will be buying Hyundais ;)
Postby rolla_fxgt » Mon Apr 23, 2007 2:20 pm
Mr Revhead wrote:run it around a test track for 300 hours full throttle then ill be impressed 8)
I'd be impressed with the driver if they could run it round a moderately technical track for 300hours at full throttle.
Heck I'd be impressed if anyone could drive for 300 hours straight!
rolla_fxgt
Postby Mr Revhead » Mon Apr 23, 2007 2:27 pm
lol, some where like millbrook, or nardo where its a big bowl, teams of drivers, and apart from driver swap and fuel they run non stop
been a few that did it
Postby ollieboy » Mon Apr 23, 2007 7:25 pm
I'm amazed they ran it for 300 hours, I'm amazed at what a $&#$% waste of time it is.
ollieboy
Postby bluemaumau » Mon Apr 23, 2007 7:46 pm
and gas
Postby bluemaumau » Mon Apr 23, 2007 7:47 pm
i wonder if theyll show it when it $&#$% out. lol :lol:
Postby snwtoy » Mon Apr 23, 2007 8:11 pm
Screw you hippies, I'm impressed. :(
snwtoy
Postby Pies » Mon Apr 23, 2007 8:21 pm
we tried tyo blow up a lada. brick on accelerator for 4 hours before anything happened.
anything = cutting water hose, then another hour later putting stones in rocker cover
Current Rides:
Pies
Postby mr30%jr » Mon Apr 23, 2007 10:18 pm
RS13 wrote:
snwtoy wrote:Are you guys sure? 300 Hours is a LOOONG time, even for no load.
How long do you think your engine would last if you set it to 6000rpm and just lef it? :?
Its' ridiculous, and as RomanV said, to impress the non-car oriented public.
It wouldn't be very good advertising if it spat a rod after an hour or two, even if it did, they wouldn't show it. Its' neither here nor there, I would be more impressed by Hyundai announcing that they were reducing emissions, and coming up with alternative-fuel engines, not running a V6 for a couple of weeks, wasting thousands of litres of fuel, and producing several tonnes of carbon monoxide, just to attempt to prove that their engines are reliable!
Idiots.
:roll:
that takes the cake soo true write them a letter saying you apalled or howeva the hell you spell it :lol:
mr30%jr
Postby ke2nv » Tue Apr 24, 2007 12:16 am
its a @#%&@ good piece of advertising though, and its done what hyundai wanted it to do.....make people talk about it.
Adamal wrote:Aww Bae, you jus come up to a corner, and smack it back in second gear, and bounce it off da red line and turn bro! Then you stick your arm out the window and go "CHUR BAE!!!"
World's best description of "How To Drift".
ke2nv
Postby DJ » Tue Apr 24, 2007 12:19 am
300 hours?
THIS IS MADNESS
DJ
Postby RS13 » Tue Apr 24, 2007 5:25 pm
ke2nv wrote:its a @#%&@ good piece of advertising though, and its done what hyundai wanted it to do.....make people talk about it.
Yes but I sure ain't buying a Hyundai anytime soon! :)
RS13
Postby Silent Knight » Tue Apr 24, 2007 5:26 pm
DJ wrote:300 hours?
THIS IS MADNESS
No.....THIS IS HYUNDAI!!!
Silent Knight
Postby Fortyone.co.nz » Tue Apr 24, 2007 6:52 pm
Not impressed here. No load, it uses external cooling (water is fresh and cold, it's certainly not hooked up to a radiator of any kind that you'd expect on a car), it uses an external oiling system (I assume), low redline, simple engine, there's no "underhood" temperatures to consider, yaddy yaddy ya.
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby big_boy » Tue Apr 24, 2007 7:12 pm
put it in a box 1.2m square & self contained & then add say 2 tork converters coupled to each other & with 1 end of the 2nd one solided mounted 8O
then il be impressed
also i wana see a 3 or 4K do this test as i would reckon you would get at least that & it would only cost you about 150L in gas to do
for sale EE90
big_boy
Postby SUBARUCONVERT » Wed Apr 25, 2007 11:47 am
yes a rather meaningless test, usually external factors kill an engine (bad cooling system, lack of oil, bad tuning etc) my fav test was subarus 0-100,000 km record attempt with the original RS legacy in 1989, entered 3 cars, they all finished, within 3 laps of each other at a avg speed of 223 kph. now thats a test
3ST150
SUBARUCONVERT
Postby method » Wed Apr 25, 2007 12:39 pm
Yeah it a meaningless test however a lot of car makers do that.
Im sure it just a way of checking the robots put it all together right. That its not off balance or what ever and the the materials used are consistent.
Be funny if you had a bad batch of steel and as a result all your conrods would just snap.
Obviously there are other ways of checking for this but its just one of the tests car makers do.
Mazda famously did it with one of their rotors, was for a stupidly long time (months) at redline.
Think it may have been to do with the development of the lemans engine?
PICS UPDATED DAILY
method
Postby Chickenman » Wed Apr 25, 2007 12:40 pm
I'm sure under the same circumstances as the hyundai ad a 4k would outlast the cockroaches.
Baby Jesus
Chickenman
I Am The Walrus!
