Decisions on best Targa car
Postby Si » Sun Jul 15, 2007 9:18 pm
http://www.trademe.co.nz/Trade-Me-Motors/Cars/Toyota/auction-108028132.htm?p=10
Now that would be a quick, albet handfull, of a targa car!
Lynn Rogers built race 3SGTE 2800kms old entailing
Custom JE forged pistons 86.5mm
Custom Saenz Forged Conrods
TRD bearings
HKS 272 In/Ex cams
HKS Cam gears
HKS 1mm head gasket
HKS valve springs
Tapped and widened oil gallies
Modified oil pump
Lynn Rogers Head port and polish
Block de-burred
Lightened and balanced crank
TVIS removed
9:1 CR
Greddy turbo kit
T78-33D 17cm2 turbo
Type R W/G
Trust SUS304 manifold
80mm down pipe
Current: , '96 SubaruImpreza
Si
Postby Mr Revhead » Sun Jul 15, 2007 9:59 pm
strx7 wrote:
Al wrote:E36 M3. The 3 litre one. You would be looking at a higher km one though.
cheaper, same if not more power and more reliable = get a 325i and put a worked 2JZGE with individual TB's on it. Same sound, toyota reliability, ease of parts, what more could you want?
:lol: thats your answer for everything :lol:
im suspecting you have a surplus of 2JZs your wanting to unload! :P
whos SW20 is that???
Postby Dell'Orto » Sun Jul 15, 2007 10:04 pm
Thats pretty high comp for a turbo that large...wonder if the idea was to try spool it quicker at the expense of out and out power.
Definately not what I'd use as a Targa car!
Postby strx7 » Sun Jul 15, 2007 10:40 pm
Mmm, Boost wrote:Thats pretty high comp for a turbo that large...wonder if the idea was to try spool it quicker at the expense of out and out power.
higher compression ratio means a few things
a) spools the turbo faster
b) perkier off boost
c) more HP for the same PSI
Postby Dell'Orto » Sun Jul 15, 2007 10:44 pm
Yep, but its also gonna limit what kind of boost pressure you can run. A T78 isnt really gonna be all that efficient at 1 bar. I'd swap to something more like a GT3071 and have a far broader powerband.
Postby strx7 » Sun Jul 15, 2007 10:46 pm
Mr Revhead wrote:[
Nah, I just think that the 2JZGE is such an overlooked engine. Find me another engine out there which can be readily purchased for under $1000 which with just bolt ons will happily take over 600HP at the flywheel reliably. (turbo'd of course)
So many people seem to be of the opinion that turbo'ing is the only option for a performance engine. Sure slapping a turbo on gives you a good gain of power, but it also gives you all sorts of problems, particuly in a vehicle which gets prolonged useage ie: rally or endurance race. a tickled 2JZGE would be a GREAT engine for such an application, I'd be amazed if someone actually killed one in N/A form. It'd sound very similar to a worked 6 cyl from back back in the days ala XU1 Torana etc so the older motorsport faternity would think it was wonderful too.
Postby strx7 » Sun Jul 15, 2007 10:47 pm
Mmm, Boost wrote:Yep, but its also gonna limit what kind of boost pressure you can run. A T78 isnt really gonna be all that efficient at 1 bar. I'd swap to something more like a GT3071 and have a far broader powerband.
add water injection and boost is your oyster.
do you know what compression the national rally championship cars run?
Postby Mr Revhead » Sun Jul 15, 2007 11:00 pm
about 15-18 psi
Postby strx7 » Sun Jul 15, 2007 11:15 pm
Mr Revhead wrote:about 15-18 psi
?????? I didn't ask what boost they run. I asked what compression they run. But yeah they run that boost and as higher compression as they can with pump gas and that boost level, which is usually around 10:1 compression
Postby Mr Revhead » Sun Jul 15, 2007 11:20 pm
:lol: sorry, distracted by the porsche doco on sky :P
compression is stock on a group N car
Postby nzae86 » Sun Jul 15, 2007 11:35 pm
Just build your self another ae86 or fix the one that you have , you know that they are as fast as a Honda anyway ! :lol: and paint it yellow this time !
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby neo » Mon Jul 16, 2007 12:48 am
Import used Corolla WRC car from England. =) [lots of hassles getting it registered but, muh what price can you put on fun!]
4wd, 3SGTE, 1 tonne... and they go better when you use Toyotas fancy expanding turbo restrictor :lol:
neo
Postby TRD Man » Mon Jul 16, 2007 9:55 am
beeker, ultimately a GT3 is probably where it's at if budget's not an issue. If it is then it's worth considering that the cheapest rally car car you'll ever build is the one you already own.
Assuming you still have the Type R you'd be better off sorting out whatever issues you have with it. These cars have been used to very good effect at the pointy end of Targa and other seal events and I'd suggest that if you're having the troubles you describe it's a setup and/or a driving style problem.
If you can get the hang of driving FWD quickly you'll be going a lot faster than you will in a RWD car - and you won't have had to spend all that money on a new car to do so.
TRD Man
Postby Mr Revhead » Mon Jul 16, 2007 10:04 am
failing that, ring up mcandrew and coppins and tell them they better stop winning coz their cars are crap
Postby Dell'Orto » Mon Jul 16, 2007 7:09 pm
I was gonna, they're probably quite high. But then they also tend to be rebuilt quite frequently don't they?
Postby fangsport » Mon Jul 16, 2007 7:31 pm
only the Subarus.
fangsport
Postby Mr Revhead » Mon Jul 16, 2007 11:20 pm
:lol: actually id say the mitsis are a lot worse!!
specially the evo nines, they just now seem to be getting them to the point where they can finish!
the only engine damage we had was when a certain car landed on its roof, and when launch control was used for too long :?
Postby MikeMan » Wed Jul 18, 2007 2:17 pm
strx7 wrote:Nah, I just think that the 2JZGE is such an overlooked engine. Find me another engine out there which can be readily purchased for under $1000 which with just bolt ons will happily take over 600HP at the flywheel reliably. (turbo'd of course)
VH41DE :D
MikeMan
Postby Prymal » Fri Jul 20, 2007 12:36 am
Why not a St165 Gt4 with St205 running gear
Classic looks of a PROPER rallycar , with a tried and tested history of success , still toyota - AWD , lightest of the fours ..
theres about 3 for sale on trademe atm that could be perked up to be targa weapons
OR get an RC - full castrol replica decals , upspecced running gear ( 205 box and brakes for starters ) and do a tribute car ..
Prymal
Postby sergei » Fri Jul 20, 2007 10:25 am
I am going ST165 route but I cannot afford targa (right now I cannot afford even rollcage)... After purchase of ST205, ST165 project become a long term one. I do not regret buying ST205 - great car!
