IH8TEC wrote:there is nothing wrong with 25psi on 98, as long as your tuner is not a munter (pretty sure andre ISN'T), barry tuned his on 98, thats 27psi (has gone to 30psi too) and 70kw more. just make sure you have colder plugs, recommend 8's or even 9's, and gap them right.
it's nothing to do with common sense it's very doable.
by the sounds of it you want well over 300kw somewhere, either go 800's or even 1000's if you wanna try match the power some of the guys are making around the world.
method wrote:I've always thought of the 4age as one of the best "bang for buck"' engines. You can get cast turbo manifolds off ebay for $100, put a turbo on and make a fair wack of power for under $1,000
Managed to get 260kw on 20psi but that was with 100% injector duty cycle.
JustinSpiderholden wrote:Ok
first person in nz, to make more than 300kw with a turbo 4age still 1600cc or less I will buy a box of beers
Chur
The levin on trade me the 355hp is at the wheels was tuned on nz efi's dyno
Oh BTW for the beer the dyno reading cannot be from tricky tune or tourque performance
~SlideWays~ wrote:JustinSpiderholden wrote:Ok
Chur
Thats gotta be some good/expensive beer...
EDIT: 355hp atw is just slightly over gasman's new figure... interesting.
IH8TEC wrote:there are two people i can tell you straight up,
LOTOY in a ke30? runs low 11's, massively worked head.
and Kent from speedsources cousin has 320kw at the rear wheels in a red dx wagon with gt3040, revs to 10k, and 20psi boost, he mentioned that was without the nitrous too;
cogent wrote:just had a look on ebay myself. Cast manifolds for like $60US, and I also found this:
http://cgi.ebay.com/ebaymotors/Toyota-C ... enameZWDVW
Assuming $100US for shipping to nz, thats less than $800NZ for a manifold, turbo, oil lines, gaskets and fittings. crikey.
Obviously it could be a case of get what you pay for, but still.
l1ttle_d3vil wrote:$175 cast manifolds on trademe - not sure if the guy is importing more though?
http://www.trademe.co.nz/Browse/Listing ... =147348207
gasman wrote:im running 550's on the stock fuel pressure regulator, i have a sard one mounted up and all ready to be plumbed up but andre said it still wont be enough fuel anyway. I was going to push it to 25psi but common sense and safety stopped me on 98.
I will however push it once i save up enough for some bigger injectors and some C16.
The destroked 4age that Bob Norwood is running seems very impressive but i can find any power numbers in that article.
Users browsing this forum: Bing [Bot] and 16 guests
