lowglrolla wrote:my 89 ae92 has factory lsd box, always used to leave two black lines . when on 15" wheels and the front tyres would be worn out in 6months
jakesae101 wrote:mines a 88 and it left 2 black lines on the ground only issue i have with it is the clutch is sticking when fully depressed it will stay there then pop back out any ideas?
Bazda wrote: if it turns the opposite its open an open diff..
Distrb wrote:Bazda wrote: if it turns the opposite its open an open diff..
not necessarily a great test as a torsen LSD unit can behave like this. my altezza one does, as did both of my ex flatmates RZ supras
Bazda wrote:I'm referring to ae92 gtz's which never came with a torsen diff.
Distrb wrote:Bazda wrote:I'm referring to ae92 gtz's which never came with a torsen diff.
yes, however it is hard to know what is in the gearbox in question without opening it up.
rollaholic wrote:crunchy = $&#$% 99.9% of the time
good thing to try is shift it through gears without the car running and the clutch out
the only time the clutch will be causing that is if its not disengaging properly, in which case it would be affecting all gears
