jobs that shouldnt take that long but something goes wrong
Postby andyztouring » Tue Dec 29, 2009 10:55 am
Sick Puppy wrote:Stupidest five minute job was replacing bulbs on a mate's Mondeo- bulb covering is held in place with a wire coat hanger style clip. As I was putting the bulb in, the clip came out... five minute job took three hours of trying to get the fricking clip back into the mounting...
4AGE engines were nightmares to get filters off- trying to get the filter by reaching under the 'warm' exhaust manifold. :evil:
That, and the next job I'm looking forward to is replacing the sunroof motor on the Curren- only tool four years to find the information on the internet, since not a single mechanic/ panelbeater/ electrician wanted to touch it... looks to be an easy enough job lol
The sunroof job-
That job will be easy,drop the headliner,undo the drain tubes on each corner of sunroof frame,undo wires,undo all bolts holding sunroof to car roof,take out of car,remove motor ,change over motor,lube all cables etc,test everything works with allen key inserted in motor drive,then reassemble.
andyztouring
Postby FLAWLES » Tue Dec 29, 2009 11:26 am
jzx100 HID bulb covers
three out of the four screws are easily undone, the last one is hidden behind the fender
out comes teh hole lamp assy
FLAWLES
Postby Sick Puppy » Wed Dec 30, 2009 1:21 am
andyztouring wrote:
Sick Puppy wrote:... the next job I'm looking forward to is replacing the sunroof motor on the Curren- only tool four years to find the information on the internet, since not a single mechanic/ panelbeater/ electrician wanted to touch it... looks to be an easy enough job lol
The sunroof job- that job will be easy,drop the headliner,undo the drain tubes on each corner of sunroof frame,undo wires,undo all bolts holding sunroof to car roof,take out of car,remove motor ,change over motor,lube all cables etc,test everything works with allen key inserted in motor drive,then reassemble.
yeah, that is pretty much my plan... talk to the experts though and you'd think I'd asked them to perform brain surgery... from the looks of it it should be a job of a few hours tops, so why am I getting told either 'no way jose' or 'about $800 + parts'? Either way, they don't want the job... :?
How do you get the A & B Pillar panel covers off? I take it they are clipped on, so (carefully) lever them off?
Project thread here
Discussion thread here
Sick Puppy
Postby andyztouring » Wed Dec 30, 2009 7:39 am
Yes they are clipped,the A pillar has a hook at the bottom which usually hooks into dashboard,start unclipping at top and work down.
andyztouring
Postby Boosted_162 » Sat Jan 02, 2010 11:37 am
Worst job was a clutch job in my RC. Planned to do it over the 4 days of easter..... 9 months later its still not finished :lol: :lol:
Postby jakesae101 » Sun Jan 17, 2010 9:19 am
i have another to add to the list nothing went wrong we just underestermated time loudtoy said ive changed gearboxes before its easy as onece you get evrythn out of the way it will only take a couple of hours fastforward 10 hours later and we were done putting the lsd box in my trueno
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby thornz » Sun Jan 17, 2010 9:56 am
HFH on a MR2, who would have though replacing a bit of coolant hose could take soo much time/effort :lol:
thornz
Postby iOnic » Sun Jan 17, 2010 10:09 am
thornz wrote:HFH on a MR2, who would have though replacing a bit of coolant hose could take soo much time/effort :lol:
and skin 8O
Postby Brick » Sun Jan 17, 2010 11:47 am
putting an engine back together when half your bolts have been stolen :cry:
Brick
I know Kung Fu
Postby Mr Revhead » Sun Jan 17, 2010 11:48 am
Brick wrote:putting an engine back together when half your bolts have been stolen :cry:
Hmmm and I have bought a car in kit set form that I have never worked on before.... and I bet half the bolts aren't even there.... :?
Postby Bling » Sun Jan 17, 2010 11:57 am
In my experience, you only need half the bolts anyway.... well going by the number i've had left over the years :lol: :oops:
Postby captain crescent » Mon Jan 18, 2010 9:51 pm
funny thing that i work as a mechanic and i always see the other mechanics dropping bolts in to one of the many boxes of nuts and bolts sitting in a corner in the work shop then half an hour later they are scraping through the boxes looking for those bolts lol DUH!!!!!
Budweiser is a gay beer. if it isn't a gay beer Sam why are you trying to put it up my arse.
captain crescent
