Dragger_Dan wrote:About 2700 @ 100 in the AW11. Sadly that's with higher profile than standard tires on the back, so I'll probably loose a bit of economy when I put proper tires on it.
Adamal wrote:Was thinking about this thread whilst driving last night and found something interesting in the SW20.
At 3000RPM:
1st gear: 20kph
2nd gear: 40kph
3rd gear: 60kph
4th gear: 80kph
5th gear: 100kph
Goes up in 20's.
fivebob wrote:Muzzie wrote:Can I just point out that's the wrong car
Thats a Series 2, with 1400 turbo.
The earlier 1300 were quickerAnd I have the earlier
As long as I can point out that your car has less HP (105 @5750) and lower top speed (196km/h)![]()
BTW if this car is the right one the Final drive is 3.59 and top gear is 0.863, thus making you tacho error even more Vague-lia
RomanV wrote:Was thinking about this thread whilst driving last night and found something interesting in the starlet.
At 80kph and full throttle:
5th gear: Brrrrrraaaa
4th gear: BRRRR!
3rd gear: BRRRAAAAAA
2nd gear: BRAAAADIDIDIAAAA
1st gear: DIDIDIDADAA*CLANK*BOOM!*
Life without a tacho is so much simpler.
