Whats Your Revs To Speed?
Postby riddles » Thu Oct 06, 2005 1:42 pm
So to compare differences, can anyone tell me what the original specs were for a ST205, I've tried google but can't seem to ask the question in the right way.
riddles
Postby fuel » Thu Oct 06, 2005 3:17 pm
Dragger_Dan wrote:About 2700 @ 100 in the AW11. Sadly that's with higher profile than standard tires on the back, so I'll probably loose a bit of economy when I put proper tires on it.
It's probably the other way around. The amount of revs the engine is doing doesn't accurately indicate how much fuel you are going to use. You could be in 3rd gear at 50km/h at say 3000rpm or in 4th gear at 50km/h at say 2000rpm, if you load up the motor (ie going up a hill), you are going to use more fuel in 4th doing less revs. The same works for tires, if you have a larger than standard diameter, for starters your speedo will be out, you'll have a theoretical higher top speed, but your engine will have to work harder to get the acceleration, so more fuel usage.
My car is meant to have 205/50R16 tires but I used 205/55 R16 which is about 5% out. When I put 205/50 R16s back on, it didn't feel so sluggish, and I got better overall fuel economy.
LOUD NOISES!!!
fuel
Postby Adamal » Thu Oct 06, 2005 3:43 pm
Was thinking about this thread whilst driving last night and found something interesting in the SW20.
At 3000RPM:
1st gear: 20kph
2nd gear: 40kph
3rd gear: 60kph
4th gear: 80kph
5th gear: 100kph
Goes up in 20's.
Postby Skidman » Thu Oct 06, 2005 5:12 pm
The Bluey does 2700 at 100
and the RF400RP manages 6000 at 100ish
ST162 3000ish at 100
(all manual of course)
Hondas are made for people who dont know better.
Skidman
Postby XERO » Thu Oct 06, 2005 5:46 pm
Adamal wrote:Was thinking about this thread whilst driving last night and found something interesting in the SW20.
At 3000RPM:
1st gear: 20kph
2nd gear: 40kph
3rd gear: 60kph
4th gear: 80kph
5th gear: 100kph
Goes up in 20's.
Dude thats amazing... Good work...
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby Adamal » Thu Oct 06, 2005 5:59 pm
Its good to see my degree in quantam physics didn't go wasted.
Postby no_8wire » Thu Oct 06, 2005 6:07 pm
its about the same in the AW11...you inspired me to conduct the same test...
no_8wire
Postby ee904age » Thu Oct 06, 2005 6:08 pm
3400RPM @100KPH in the Corona with 195/60 14's
I think it would hit the rev limit before the speed cut :cry:
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
rev
Postby Hoppy89 » Thu Oct 06, 2005 9:26 pm
3000 in the in my 2e at 100
Current ride Gti-16 Corolla
previous rides
ae-82 fxgt
2e ae-96 wagon
ee90 2e liftback
Hoppy89
Postby fuel » Thu Oct 06, 2005 9:28 pm
2100rpm in top gear at 100km/h in my old '87 Sigma.
LOUD NOISES!!!
fuel
Postby MrBeef » Thu Oct 06, 2005 10:48 pm
well using that page, after finding out my final drive and gear ratio of my c52 gearbox on a 4a-f, running i *think* 175/75/R13
i do about 3100 revs yeh.
Any last words?
Box, toaster, Aluminum, Maple syrup...no I take that back..im'a hold onto that one.
My beast!
MrBeef
Postby slighty_sykotic » Mon Oct 10, 2005 11:25 pm
mine is damn near dead on 3500 on a 1991 ae101 20v, with 205/40/r17 tyres at 100km/h......i sometimes wish it was lower (6 speed? :twisted: ) simply to reduce cabin noise a bit.
No other ae101 people reading this thread?...
--Sykotic
slighty_sykotic
Postby Bling » Mon Oct 10, 2005 11:26 pm
2800 @ 100km/h, 95 Hiace :lol:
Re: Whats Your Revs To Speed?
Postby Steve123 » Sat Jan 28, 2006 11:02 pm
fivebob wrote:
Muzzie wrote:Can I just point out that's the wrong car :)
Thats a Series 2, with 1400 turbo.
The earlier 1300 were quicker :) And I have the earlier :P
As long as I can point out that your car has less HP (105 @5750) and lower top speed (196km/h) :P
BTW if this car is the right one the Final drive is 3.59 and top gear is 0.863, thus making you tacho error even more Vague-lia :D
:lol: Vague-lia
yep, the tach is wrong, it should indicate around 3200rpm@100km/hr. Top speed is 200km/hr.
Steve123
Postby 1loose_mr2 » Sat Jan 28, 2006 11:12 pm
aw11 does about 1300 @100 and about 4000 at 180 with over switch on
1loose_mr2
Postby sergei » Sat Jan 28, 2006 11:36 pm
Do you guys realize if you going to compare speed of car speedometer vs tacho, the wheel size DOES NOT MATTER, it will always show say 3100 in 6th @ 100kph, no matter what wheel diameter. That is assuming speedo has not been calibrated for new wheels.
Postby DJ » Sun Jan 29, 2006 1:22 am
2500rpm @ 100kph (4th gear)
DJ
Postby RomanV » Sun Jan 29, 2006 1:39 am
Was thinking about this thread whilst driving last night and found something interesting in the starlet.
At 80kph and full throttle:
5th gear: Brrrrrraaaa
4th gear: BRRRR!
3rd gear: BRRRAAAAAA
2nd gear: BRAAAADIDIDIAAAA
1st gear: DIDIDIDADAA*CLANK*BOOM!*
:twisted:
Life without a tacho is so much simpler. :)
Postby RedMist » Sun Jan 29, 2006 8:39 am
Bunderson with a 4 Speed Rose transaxle and on enduro 32 inch tyres.
100kph - 4800 RPM.
170kph - 8300 RPM.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby XERO » Sun Jan 29, 2006 6:38 pm
RomanV wrote:Was thinking about this thread whilst driving last night and found something interesting in the starlet.
4th gear: BRRRR!
:twisted:
Rofl :lol:
XERO
