Test day this sat @ Puke
Postby cat007 » Fri Apr 17, 2009 4:35 pm
Bazda wrote:
You need really stiff suspension with slicks. Or they will go off very quickly.
go off? you mean over heat? or?
Postby Bazda » Fri Apr 17, 2009 4:41 pm
yea over heat.
Postby cat007 » Fri Apr 17, 2009 5:01 pm
Bazda wrote:
yea over heat.
Hmm - well Puke shouldn't put too much on them as there's really only a few testing corners. Maybe at a more cornery track.....??
How would I know if they're overheating? Would they delaminate or just become slippery?
Postby Bazda » Fri Apr 17, 2009 5:18 pm
just become slippery as.
Should be ok, they are older tyres from a V8?
Postby Trevor » Fri Apr 17, 2009 5:20 pm
You will lose a lot of grip all round, but probably get alot of understeer mainly as sounds like your car has a tendancy to push already. With softer suspension you will be getting alot of tyre movement as you have more weight transfer if I understand correctly, similair to running tyre pressure too low, and therefore cause the tyres to overheat.
Trevor
Postby cat007 » Fri Apr 17, 2009 5:31 pm
Bazda wrote:just become slippery as.
yeah - not the big ones - but the v8 touring type I'm told...
Postby cat007 » Fri Apr 17, 2009 5:32 pm
Trevor wrote:You will lose a lot of grip all round, but probably get alot of understeer mainly as sounds like your car has a tendancy to push already. With softer suspension you will be getting alot of tyre movement as you have more weight transfer if I understand correctly, similair to running tyre pressure too low, and therefore cause the tyres to overheat.
well hopefully my suspension isn't too fu**ed :)
Postby Trevor » Fri Apr 17, 2009 5:43 pm
Only way to find out is to give it a go haha :D. Fun times on the edge
Trevor
