Bazda wrote:
You need really stiff suspension with slicks. Or they will go off very quickly.
go off? you mean over heat? or?
Bazda wrote:
yea over heat.
Bazda wrote:just become slippery as.
Should be ok, they are older tyres from a V8?
Trevor wrote:You will lose a lot of grip all round, but probably get alot of understeer mainly as sounds like your car has a tendancy to push already. With softer suspension you will be getting alot of tyre movement as you have more weight transfer if I understand correctly, similair to running tyre pressure too low, and therefore cause the tyres to overheat.
