Dyno plot guessing game!!!
Postby RobertC » Thu Jun 02, 2011 10:33 pm
Honda engine? 2<?<2.5L
RobertC
Postby blindnz » Thu Jun 02, 2011 10:38 pm
BZG|Bling wrote:Maybe I just haven't seen enough dyno plots...... but that is the smoothest one i've seen. I'll go left-field and say he's stolen a Prius' heart :lol:
Yeah man thats so linear. Electric motors arent linear power curves though either. I thought they make max power roughly 1/2 max rpm...
I have no clue what it is.
blindnz
Postby Lith » Thu Jun 02, 2011 10:46 pm
RobertC wrote:Honda engine? 2.2?
Damn you, I thought this'd be harder! Nice work :)
2007 Mazdaspeed Axela
Lith
Postby blindnz » Thu Jun 02, 2011 10:52 pm
H22A? or variant of? everyone I've driven had a real vtec kick so would have thought it wouldnt have such a smooth power curve.
blindnz
Postby Lith » Thu Jun 02, 2011 10:57 pm
Its a modified (but still naturally aspirated ) H22A in a Type-S Prelude :)
I was hoping the smooth curve would put people off the scent...
Lith
Postby touge_ae101 » Thu Jun 02, 2011 11:18 pm
that is very impressive power even from a h22! but yeah i understand its quite modified though. how big are the cams? very impressed by smoothness!
touge_ae101
Postby Lith » Thu Jun 02, 2011 11:28 pm
touge_ae101 wrote:that is very impressive power even from a h22! but yeah i understand its quite modified though. how big are the cams? very impressed by smoothness!
Quite big, Skunk2 Pro2 cams... they are 302/312deg with lots of lift on Hi-Cam iirc, but the low cam is also quite agro so it makes more than a typical NA 4 even off VTEC.
He has a build thread NZHondas if you have a logon there: http://nzhondas.com/forum/build-threads/84176-h22-na-build-bb6-dh-1-06-2011-dh-185dt6wkw-mobil-98-factory-rev-limit.html
Lith
Postby Flannelman » Fri Jun 03, 2011 7:37 pm
Take it by the steady rise of power, torque is like a table top?
Flannelman
formerly known as Affroman
Postby Lith » Fri Jun 03, 2011 7:59 pm
Reasonably so for a VTEC Honda - torque was still climbing.
Here is the full unedited screen shot from the tuning session:
Lith
Postby Flannelman » Mon Jun 06, 2011 9:00 pm
Can we have that again, please?
Flannelman
Postby Lith » Tue Jun 07, 2011 10:42 am
Ahhh its hosted on NZHondas, didn't pay attention to that- wouldn't see anything unless you are a member.
Here:
Its going to be running at the NZHondas dyno day in Welly this weekend, haven't decided whether to try and get a few hundred more rpm out of it before then or not.
Lith
Postby Mr Ree » Wed Jun 08, 2011 12:47 pm
A few hundred more?
10k FTW ;)
wak thud gush!
Mr Ree
Postby Lith » Wed Jun 08, 2011 5:47 pm
Eek!! At the 8,500rpm we aim to rev it to, it will already have the piston speed of a 2JZ running to 9,000rpm... in combo with a fairly brutal 1.58 r/s ratio thats probably more than sufficient stress for a road car! 8O We'll probably just do that tune on on E85 too, its (unsurprisingly) octane limited on Mobil 98.
I'm guessing you can tell we've got on top of the E-Manage as well, seems to go well though is still definitely a compromise in some ways - I'm sure I could get the car behaving a fair bit nicer with a proper "full control" ECU, the stock OBDII closed loop lambda situation can make life a bit tricky for starters... with all the head work the engine doesn't really want to idle nicely with the kind of mixtures an "off the factory floor" engine would :(
You should come down check out the NZHondas dyno day at STM on Saturday if you haven't got much happening and feel like some shxt talking - I'll be lurking around much of the day as a few cars I've tuned will be running (including this one).
Lith
Postby Mr Ree » Fri Jun 10, 2011 2:56 pm
Good to hear you got some positive results with the ECU mate :)
I just got a WOF on the car yesterday so if it isnt pissing down, I might venture out for a look. How many cars are going on the dyno through the day? Any known weapons attending? You?
wak thud gush!
Mr Ree
Postby Lith » Fri Jun 10, 2011 4:45 pm
My car won't be running, there are about 20 cars lined up.
The day starts at 9, and that angry (for an NA) Prelude will be 3rd, and then an R33 GTS25t with stock turbo which I also tuned will be running after him, an Torneo which I believe Simon may have been around while I was tuning is also running (made 156kw last time, new owner wants another go), a supercharged Jaguar, a Turbo Type-R Integra, an 11 second EVO, Luke will be there with his now turbocharged Supra but not running it on the dyno, a few rotaries and some other cars I know no detail about.
I'm going to be there from just after 9, give us a text if you want. My car is having a bit of a holiday while I plan its fate ;)
Lith
