Postby iOnic » Sun Dec 15, 2013 8:21 pm
Accidentally entered a car show. Just as well I went through a car wash before
Had this sweet Camry next to me
Postby Mr Ree » Sun Dec 15, 2013 9:06 pm
Ive always wondered what my Gen 3 Camry wagon would look like, lowered on widened steelies, with bulging tyres etc, but I have a feeling it would never look that good ^
wak thud gush!
Mr Ree
Postby Leon » Sun Dec 15, 2013 9:06 pm
Notion Wairarapa.jpg (191.83 KiB) Viewed 5192 times
Autocrossed it!
Postby thegreatestben » Sun Dec 15, 2013 9:23 pm
Haha saw you this morning, that was me in the black cressida wagon on sh2
thegreatestben
Postby Leon » Sun Dec 15, 2013 11:06 pm
Ah the 2.4D badged one?
Postby thegreatestben » Mon Dec 16, 2013 7:03 am
Yup yup, 2L diseasel thriftiness.
thegreatestben
Postby CAMB01 » Mon Dec 16, 2013 11:13 pm
Found leak in the radiator of my daily corolla after replacing the rad cap as i thouht it was leaking due to no pressure in cooling system. Dropped radiator off this morning to be repaired. Came back this arvo repaired and i owe them a box of beers. Cheap fix FTW. Oh and it never overheated just noticed a smell of coolant sometimes and the lack of pressure when squeezing hoses.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Mr Ree » Mon Dec 16, 2013 11:40 pm
Over the weekend, I ripped into unwrapping the entire engine wiring loom, so I can go about relocating the various sensors from the other side of the engine bay, like the TPS, IACV, IAT etc. It looks like a massive nightmare waiting to happen, but Im trying to be careful and tagging anything Im a little wary of.
I soldered up a new harness for my COP conversion to avoid any potential issues with old cracked connectors.
I deleted my charcoal canister so I would have room to relocate my remote oil filter set up
I covered all of my -10 braided oil cooler lines in conduit as I got sick to death of being pricked when ever I brushed past them. It will also stop the lines potentially causing damage by rubbing through other things in the engine bay.
I got dynaflow to make me an extra long SS braided PTFE oil feed line for my turbo, so I can run it from the new oil filter position, and around the engine to the turbo, instead of over the top of the new cam covers.
I bought a small lightweight drycell battery, as the old one was too big to squeeze in between the Q45 throttle body, and the headlight. It has its own metal jacket to affix to the car to help with mounting it, so Ill just need to make a bracket to go over the top of it to hold it in place.
I got a small sheet of 6mm perspex that I will cut up to make a new low profile fuse box, so I can tuck it under the new plenum, now that there is no room for the factory fusebox due to the same throttle body ^ lol
Bought some more conduit to put around all of my braided oil cooler lines
Cursed that I cant find any ECU terminals, and then went home.
wak thud gush!
Mr Ree
Postby Grrrrrrr! » Sun Dec 22, 2013 8:04 pm
Finally got round to cleaning the inside of the honda.. 4 hours later the glass is spotless (expect that nearly impossible to get to bit behind the high stop light), the interior rubber and plastics are as clean as they are going to get and the carpets have been cleaned, outside of the car has also been washed. Not quite Concours standard, but pretty good. Now I just need to hit up Strong/Torque Performance for some replacement interior bits to replace the stuff that is beyond salvaging (drivers mat, B pillar trim on passengers side and gear knob)
Grrrrrrr!
Postby 2jayzgte » Mon Dec 23, 2013 12:31 pm
Fuelled loaded and ready for my annual pilgimage to Gisborne.
Bayview to Gisborne rd awaits.
2jayzgte
Postby Mr Ree » Mon Dec 23, 2013 1:16 pm
2jayzgte wrote:Fuelled loaded and ready for my annual pilgimage to Gisborne.
Safe travels, mate :)
All the best, and I will catch up with you in the new year before our annual pilgrimage to Taupo ;)
wak thud gush!
Mr Ree
Postby shogun » Mon Dec 23, 2013 5:56 pm
Been saving up to get a decent set of wheels and replace those ugly Advantis that came with the car.
Two of the wheels were slightly damaged so I fixed them at work and whacked them on. Looks way better IMO.
They are 16" SSR Type V
1992 AE101 Corolla FXGT
shogun
Postby Stott69 » Tue Dec 24, 2013 5:47 pm
Drove the Aristo, got stuck at the mall due to dead battery even tho its been on charge for a week. So brought a new battery to jump start me to get home.
Then had trouble finding the bonnet release on the new Focus. Theres a key hole behind the front badge to pop it..... ???
Stott69
Postby Lloyd » Tue Dec 24, 2013 5:59 pm
A fair few fords have had that for about the last decade or more. I'd imagine it to be quite frustrating the first time :P
Postby Stott69 » Tue Dec 24, 2013 7:38 pm
Yea, had to google it. Just plain weired tho....
Stott69
Postby steroidcontaskie » Tue Dec 24, 2013 11:44 pm
Had oil leak at turbo feed flange, replaced Chinese crap with name brand part, looks like problem is fixed.
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby iOnic » Thu Dec 26, 2013 10:53 pm
Installed HID reverse lights
Postby Vertigo » Fri Dec 27, 2013 10:05 pm
Spent the day sheering bolts, apparently.
TVIS just kicked in, yo!
Vertigo
Postby jacobrjett » Sat Dec 28, 2013 11:43 pm
iOnic wrote:Installed HID reverse lights
thats cool, never thought of that. does it make a big difference at night?
jacobrjett
Postby iOnic » Sun Dec 29, 2013 12:54 am
Yeah that's why I put them in. Privacy glass is a bitch at night. Not sure if 6000k is the best for the job but it's way better than stock.
Users browsing this forum: No registered users and 32 guests
