Mmm, Boost wrote:I doubt anyone will tell you it wont work, pretty sure everyone will be very keen to hear audio clips of it running
Mmm, Boost wrote:I thought in the later battles he did use an Atlantic engine?
/ot
matt dunn wrote:Found this and though it may be relivant to this topic.
Note that I presume the prices are in USD.
http://www.toysport.com/New%20Products/Atlantic.htm
nzae86 wrote:Every one can try and tell me it wont work but at least I'll know because I will have done it .
Mr Revhead wrote:hehe then you consider that for the valve bits you multiply it by 16 and it soon gets exspensive!.
JT wrote:With how much gas? My car must have a heavy bonnet as with 3/4 of a tank of gas, basically standard GTV it came in at 990kg. Scales are accurate to +or- 5kg.
NZ_AE86 wrote:Not much gas but a full tank will be less then 50ish kgs, my car is a race/rally car - no interior - no sound dead material - no heater - no unrequired things under the bonnet - no stereo etc etc
I assume yours is the road car in your profile? I would say that if you remove all that stuff yours would be 60-80 kgs lighter then mine and then when you put a cage in it will be similar?
NZ_AE86 wrote:...no real weight savings except fibreglass bonnet is 870kgs.
JT wrote:NZ_AE86 wrote:...no real weight savings except fibreglass bonnet is 870kgs.
Probably adds up about right though. 86factory.com reckons fibreglass bonnet saves 32kg
JT wrote:
Yeah, one in profile is it.
Just in your other post you said..NZ_AE86 wrote:...no real weight savings except fibreglass bonnet is 870kgs.
Users browsing this forum: Google [Bot] and 24 guests
