Found this on my bench
Postby Dell'Orto » Sat Sep 30, 2006 11:52 am
I doubt anyone will tell you it wont work, pretty sure everyone will be very keen to hear audio clips of it running :D
Postby JT » Sat Sep 30, 2006 7:03 pm
Mmm, Boost wrote:I doubt anyone will tell you it wont work, pretty sure everyone will be very keen to hear audio clips of it running :D
Hell no, I want a ride in it! :D
JT
Postby DriftMonkey » Sat Sep 30, 2006 8:46 pm
Mmm, Boost wrote:I thought in the later battles he did use an Atlantic engine?
/ot
Narp, Group A AE111 engine AFAIK
DriftMonkey
Postby matt dunn » Sun Oct 01, 2006 12:23 am
Found this and though it may be relivant to this topic.
Note that I presume the prices are in USD.
http://www.toysport.com/New%20Products/Atlantic.htm
Postby AE85coupe » Sun Oct 01, 2006 1:15 am
matt dunn wrote:Found this and though it may be relivant to this topic.
those prices are not as bad as i expected
except for the crank! shit thats pricey
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Mr Revhead » Sun Oct 01, 2006 5:27 pm
hehe then you consider that for the valve bits you multiply it by 16 and it soon gets exspensive!.
Postby wde_bdy » Sun Oct 01, 2006 5:43 pm
nzae86 wrote:Every one can try and tell me it wont work but at least I'll know because I will have done it .
I would get in touch with http://www.club-k.co.nz/Full039.htm, I think Jamie is around here occasionally as Jimtune (more regularly on Club K). Nothing likely talking to someone who is actually using a similar setup to what you have planned.
Callum
wde_bdy
Postby Si » Sun Oct 01, 2006 6:13 pm
Mr Revhead wrote:hehe then you consider that for the valve bits you multiply it by 16 and it soon gets exspensive!.
Indeed very very $$$$$$
Current: , '96 SubaruImpreza
Si
Postby Dell'Orto » Sun Oct 01, 2006 6:17 pm
So a fraction over $26k for a motor that doesnt idle, makes no power til 6,000rpm, and has to be rebuilt every 20 hours of running?
Who's got a credit card with that sort of limit :twisted:
Postby Si » Sun Oct 01, 2006 6:20 pm
26k just for the internals.....
you then need block and head,
and then balancing fully............
brad have you also noted our txt talk signature is broken? no more animation!
Si
Postby nzae86 » Sun Oct 01, 2006 6:26 pm
Keep in mind that doesn't get you a dry sump set up, plumbing, flywheel and clutch set up , carbs and manifolds, porting and balancing, and countless hours to put the thing together with dyno time. Those prices are only the basis to start with , and at the end of that part you still ony have a motor ! Spose I could just finish the motor and use it as a coffee table .
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby Mr Revhead » Sun Oct 01, 2006 6:28 pm
you should get 4 of them
and use them to make a pedestal for your shiney yellow one :P
Postby NZ_AE86 » Sun Oct 01, 2006 6:37 pm
JT wrote:With how much gas? My car must have a heavy bonnet as with 3/4 of a tank of gas, basically standard GTV it came in at 990kg. Scales are accurate to +or- 5kg.
Not much gas but a full tank will be less then 50ish kgs, my car is a race/rally car - no interior - no sound dead material - no heater - no unrequired things under the bonnet - no stereo etc etc
I assume yours is the road car in your profile? I would say that if you remove all that stuff yours would be 60-80 kgs lighter then mine and then when you put a cage in it will be similar?
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby NZ_AE86 » Sun Oct 01, 2006 6:40 pm
It will work, very well! May be good for track work only but that is fine! 8)
Current rides;
1986 Levin GT
NZ_AE86
Postby JT » Sun Oct 01, 2006 11:12 pm
NZ_AE86 wrote:Not much gas but a full tank will be less then 50ish kgs, my car is a race/rally car - no interior - no sound dead material - no heater - no unrequired things under the bonnet - no stereo etc etc
Yeah, one in profile is it.
Just in your other post you said..
NZ_AE86 wrote:...no real weight savings except fibreglass bonnet is 870kgs.
Probably adds up about right though. 86factory.com reckons fibreglass bonnet saves 32kg
JT
Postby fangsport » Sun Oct 01, 2006 11:40 pm
saves 32kg????????? are they lead from factory.
the more i hear about their weight, the more happy i am with the TE71. diet consists of sound deadening, basic loom and lighter bumpers and last weighed in at 930kg with fuel and fat me (lost 10kg since then). hoping to get the sprinter under 800kg dry(target is 750kg) and road legal.
fangsport
Postby GH » Mon Oct 02, 2006 7:31 pm
Na still say bin it
GH
Postby NZ_AE86 » Mon Oct 02, 2006 7:43 pm
Sorry, by that I was meaning that I had not gone to any effort to make it light. I have only done what was required to make it a race/rally car.
If I went mad I could have another 300kgs out of it! But I need it to be road legal to do Rallies. Also it works so why touch it! 8)
Current rides;
1986 Levin GT
NZ_AE86
Postby GH » Mon Oct 02, 2006 8:24 pm
S**t bin it there has to be cheaper motorsport what about a 1uz in somethink
GH
Postby crnkin » Mon Oct 02, 2006 11:32 pm
26k gets the best money can buy if your a parts freak. You get 250hp of the most phat sounding engine ever, but, you can build one with 15hp less for 10k. Im sure no one here really is considering buying a dated engine setup new for 50k....
or are they...
deaf_homo "currrently yes"
crnkin
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 16 guests
