3s-gte rolla wagon
3s-gte rolla wagon
Postby 20v_rollaboy » Thu Dec 08, 2005 12:44 am
hey there, dus anyone out there know if this conversion has been done?
im just realising that the 4e-fte thats in it is a bit weak, and dont really wanna turbo a 4a as it will mean rebuild probably, and than the next idea was a 3s-gte.
idea was to get a Celica GTR gearbox and keep it fwd, or find a rwd or 4wd wagon and see if i can make that work.
dus anyone know if this engine would even fit into the engine bay??
20v_rollaboy
Postby CozmoNz » Thu Dec 08, 2005 8:57 am
all i can say is good luck :D
best person to talk to is probbaly Drifin_aw (all_fours on here)
whats wrong with a 4efte, spend some cash on that and you can get them very quick indeed...
Rayne For President!
CozmoNz
Postby EVL GSXR » Thu Dec 08, 2005 9:00 am
Geez not really on eto agree with Coz but yeah spend some money on the 4EFTE you can get some good power from them.. What have you done to the 4E that you have in the wagon??
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby Malcolm » Thu Dec 08, 2005 11:01 am
well, IMO the 4efte is too small for a corolla wagon, I mean it can be good in a gt starlet that is much smaller and lighter, but I reckon you'd want more torque. Also, an ideology I've picked up from much wiser people is this - if you're going to do an engine swap, you'd might aswell swap in something that's going to be a big improvement.
So, what you're talking about doing is pretty similar to the 3sgte aw11 conversion. I'd suggest getting a Celica GT-Four engine (rather than the mr2 one), as all the bits on it are already laid out for a front engine transverse set up. As for the gearbox, although an NA Celica box (S5*) will probably last alright while the engine is relatively stock, you're probably better off going straight for a beefier E series box, which will take any extra power in it's stride. Your options for the E series box are:
- E153 from an MR2 turbo, with the shift linkage that goes into the box replaced with one from a FWD E series box (including gt-four boxes)
- E5* gearbox from a manual V6 Camry or similar. Will bolt up to the 3sgte with no problems, but they're hard to find (I'm not actually even certain whether we got any manual v6's here)
- E5* 4AGZE gearbox, with the bellhousing swapped for one from one of the two gearboxes above, or a e150f (or similar) gt-four gearbox
for driveshafts you could probably go the same route as people do with the 3sgte into the aw11, that is mr2 turbo driveshafts with mr2 supercharged manual or st185 gt-four outer cv's on them, but the track width may be different on the corolla so you might have to find something else
there will be a bit of fabrication required! All the engine/gearbox mounts will have to be made, and you might have difficulties with the intake manifold on the 3sgte wanting to occupy the same space as the firewall, in which case you'll have to mount the engine further forward, which may make the driveshafts run at an unacceptable angle
and since you mentioned 4wd/rwd corollas-
I was looking over a 4age ae106(?) 4wd wagon to see whether you could swap the entire gt-four drivetrain into it. It had an E56F2 (I think), which would share 2 of it's 3 mounts with the gt-four box, but the other two would still need fabrication and using the stock mounts you might find the problem mentioned above with the intake manifold and firewall. The rear diff looked quite a bit different, and you'd probably want to use the gt-four rear diff to make sure it will handle the extra torque and the gear ratios were correct, which would mean modifying the rear subframe
and as for rwd...well there's plenty of info on 3sgte rwd conversions around
Postby FrEsH » Thu Dec 08, 2005 11:19 am
CozmoNz wrote:all i can say is good luck :D
mmm like the other guy said..4E's fine in a sub 900 kg car but i'd say tis a wee bit small in a corolla wagon :|
FrEsH
Postby rolla_fxgt » Thu Dec 08, 2005 3:20 pm
Id go the 4wd or the rwd route in the wagon aye, if your doing the conversion why not go the whole way & have something a little different?
Im still thinking of the 4wd route on the fxgt with either the gtfour running gear or a 4wd carib/corolla wagons running gear.
But this will be with a 20v turbo, though in the past i have thought of the 3sgte.
Would the caldina gtt running gear work in a corolla wagon? or is it kinda weak if u were going to mod the 3sgte? Just a thought since its allready 4wd & i guess it must be based on the gt4 running gear.
It will be a nice car. Hopefully we get to seem sum progect pics when its all done. Good luck with it all
rolla_fxgt
Postby barryogen » Thu Dec 08, 2005 3:35 pm
All_Fours wrote:- E5* gearbox from a manual V6 Camry or similar. Will bolt up to the 3sgte with no problems, but they're hard to find (I'm not actually even certain whether we got any manual v6's here)
we got there here nz new.
barryogen
2ZZ Guru in training
Postby CozmoNz » Thu Dec 08, 2005 4:07 pm
rolla_fxgt wrote:Id go the 4wd or the rwd route in the wagon aye, if your doing the conversion why not go the whole way & have something a little different?
making a fwd car rwd / 4wd is a HUGE process....
its not easy.. you see it done on race cars and such but no, wont just "happen" by sliping a fifty to your local mechanic...
talking tens of thousands of dollars
even a drop in engine can be expensive at the end of the day (4age into an ae85)... everything else needs upgraded too anyway! (brakes for starters)
i mean, with a 4efte he might get away with drummies on the rear (if it has them) drop a 3sgte in.. ull need new brakes... new hubs, new carriers, driveshaft, diff, god... its unstopable..
then you think, wel maybe gt-four stuff will fit in... no... no it wont :( (as all_fours said, engine might need to be foward slighltly because of inlet manifold, everythings harder than first thought out...
funny, me saying that, HA!
CozmoNz
Postby wde_bdy » Thu Dec 08, 2005 5:26 pm
All_Fours wrote:and you might have difficulties with the intake manifold on the 3sgte wanting to occupy the same space as the firewall, in which case you'll have to mount the engine further forward, which may make the driveshafts run at an unacceptable angle
If you have to do something about firewall clearance, getting out the gas torch/angle grinder is probably a better option than moving the engine forward. If done properly it is very easy to get past cert, guy I know did this to fit a 3S-GE into his EP71 Starlet.
Callum
wde_bdy
Postby 20v_rollaboy » Thu Dec 08, 2005 6:31 pm
hmmmmm :? :?
thank you everyone for all your input
sounds like a lot of work, much harder than my previous conversion which i done myself.
From the sound of things it would be better for me to get a accident damaged GT-4 and swap/modify everything that i need to make it fit and run. Maybe i should save up to rebiuld the 20v i have sitting in my garage and then turbo that, and get everything else i need, like ecu, brakes, turbo, allready have a manifold
or would you guys reccomend that i rather put the 20v head on a 4a-gze block.
and yea the 4e-fte is a bit small for the heavy wagon, only ran a 16s 1/4mile and its dead-even with my 20v liftback
20v_rollaboy
Postby Malcolm » Thu Dec 08, 2005 7:34 pm
everyone, please pretend you didn't read any of the following message - seriously, erase it from your mind and you will be all the better for it.
Postby Malcolm » Thu Dec 08, 2005 7:36 pm
Callum
yes, I agree, but if it's a matter of a couple of centimetres its probably easier to shift it forward. I cut the rear firewall in the aw11 for intake manifold clearance, but you have easy access to that from both sides, so its easy to weld in a little box section for it. On a front engine'd car you'd have to remove the whole dashboard which is a big PITA.
Postby Malcolm » Thu Dec 08, 2005 7:39 pm
20v_rollaboy wrote:hmmmmm :? :?
The 3sgte conversion sounds hard, but I don't think it would be too bad. If your welding isn't up to scratch, you can position the engine, make mounts and tack them into place, then get someone else to weld them in (this is what I did, got evil_si to weld them - he is local to you).
Like I said, a FWD 3sgte would be quite similar to the 3sgte -> aw11 swap, of which there are many write ups on the net. It would certainly be more rewarding than putting a 20v turbo in, and IMO about the same, or even less work - and much more potential in the end.
Postby evil_si » Thu Dec 08, 2005 7:54 pm
brad cr1mnl on here has a 3sgte corona wagon, fwd,
it has no traction it spins up without hesitation in 3rd gear,
i wouldnt bother going 3sgte fwd for that reason.
and no its not fun when trying to drive 8)
evil_si
Postby fx gt » Thu Dec 08, 2005 7:56 pm
evil_si wrote:brad cr1mnl on here has a 3sgte corona wagon, fwd,
man that sounds wicked :P
haha it was funny the other day.i did that in the fx but in 1st gear.it was at a real busy round about and i was trying to get into a spot real quick.but it didnt happen quick :P
fx gt
Postby evil_si » Thu Dec 08, 2005 8:18 pm
hahahaha wow 1st gear.
evil_si
Postby deaf_rattle » Thu Dec 08, 2005 8:47 pm
thats the car that used to have the pplate hyndri isnt it?
if so i raced it along the north western motorway one night.
there were 4 of us. that car, my supra, an rx3 an dan rx7
it was all fairly even
i thought it had a 4agte, but i guess if it did, it wouldve left me behind
I would like another go sometime when the supras back on the road. :lol:
Postby fx gt » Thu Dec 08, 2005 8:51 pm
hey hey! dont be like that
i can go 2nd gear 2 :P
fx gt
Postby 20v_rollaboy » Thu Dec 08, 2005 9:46 pm
yea this used to be HYNDRI. at the moment its just a standard starlet engine, with standard ct9, and has just had a front mount put on with some nice bling bliing piping.
still has the standard corolla exhaust so i guess thats one reason why it feels so restrictive. and i need a new gearbox :(
20v_rollaboy
Postby Santa'sBoostinSleigh » Fri Dec 09, 2005 9:15 am
Whoa Sam, your cars badass ;):P
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
