CozmoNz wrote:all i can say is good luck
best person to talk to is probbaly Drifin_aw (all_fours on here)
whats wrong with a 4efte, spend some cash on that and you can get them very quick indeed...
All_Fours wrote:- E5* gearbox from a manual V6 Camry or similar. Will bolt up to the 3sgte with no problems, but they're hard to find (I'm not actually even certain whether we got any manual v6's here)
rolla_fxgt wrote:Id go the 4wd or the rwd route in the wagon aye, if your doing the conversion why not go the whole way & have something a little different?
Im still thinking of the 4wd route on the fxgt with either the gtfour running gear or a 4wd carib/corolla wagons running gear.
But this will be with a 20v turbo, though in the past i have thought of the 3sgte.
Would the caldina gtt running gear work in a corolla wagon? or is it kinda weak if u were going to mod the 3sgte? Just a thought since its allready 4wd & i guess it must be based on the gt4 running gear.
It will be a nice car. Hopefully we get to seem sum progect pics when its all done. Good luck with it all
All_Fours wrote:and you might have difficulties with the intake manifold on the 3sgte wanting to occupy the same space as the firewall, in which case you'll have to mount the engine further forward, which may make the driveshafts run at an unacceptable angle
purple_beasty wrote:All_Fours wrote:and you might have difficulties with the intake manifold on the 3sgte wanting to occupy the same space as the firewall, in which case you'll have to mount the engine further forward, which may make the driveshafts run at an unacceptable angle
If you have to do something about firewall clearance, getting out the gas torch/angle grinder is probably a better option than moving the engine forward. If done properly it is very easy to get past cert, guy I know did this to fit a 3S-GE into his EP71 Starlet.
Callum
20v_rollaboy wrote:hmmmmm![]()
thank you everyone for all your input
sounds like a lot of work, much harder than my previous conversion which i done myself.
From the sound of things it would be better for me to get a accident damaged GT-4 and swap/modify everything that i need to make it fit and run. Maybe i should save up to rebiuld the 20v i have sitting in my garage and then turbo that, and get everything else i need, like ecu, brakes, turbo, allready have a manifold
evil_si wrote:brad cr1mnl on here has a 3sgte corona wagon, fwd,
it has no traction it spins up without hesitation in 3rd gear,
i wouldnt bother going 3sgte fwd for that reason.
and no its not fun when trying to drive
fx gt wrote:
man that sounds wicked
haha it was funny the other day.i did that in the fx but in 1st gear.it was at a real busy round about and i was trying to get into a spot real quick.but it didnt happen quick
hahahaha wow 1st gear.
fx gt wrote:evil_si wrote:brad cr1mnl on here has a 3sgte corona wagon, fwd,
