does anyone have any information on this engine? pictures or whatever? the most i found was on here http://www.toysport.com/Technical%20Inf ... rticle.htm (about half way down) and someone claiming it can handle 90PSI
Aazi wrote:Heres a couple more photos of same racing team's 503E, these were taken at 2004 so somewhat of an old setup i assume.
http://paranoia.tuug.fi/gallery2/v/fintoys/MR-2/album50/album29/185_8546.jpg.html
http://paranoia.tuug.fi/gallery2/v/fintoys/MR-2/album50/album29/185_8548.jpg.html
http://paranoia.tuug.fi/gallery2/v/fintoys/MR-2/album50/album29/185_8545.jpg.html
specs translated:
-displacement 2,1L
-compression ratio 8,0:1
-power 1150hp @ 10000rpm / 960hp with regular pump gas
-torque +1000Nm @ 6800rpm
-Weight with all equipments 210kg
-Engine management = Hestec ( http://www.sci.fi/~hestec2/english/index.htm )
-2 x 1500cc per cylinder (total injectors 8)
-Individual throttle bodies
-Dry sump oil system
-Head is magnesium
-twincam with 10-12mm lift, 16 valves
-Toyota CT44 turbo modified by til-racing
-Air to water IC
-Engine is used in a dragster which performance is 0-400m 6,91s @ 317,79 km/h, 0-100km/h in less than 0.8s and distance needed to reach 100km/h is about 15meters.
more pictures and information at team's website:
http://www.til-racing.com/
http://www.til-racing.com/inenglish.php
Mr Revhead wrote:same.....
where did the name "503e" come from? as some are of the opinion that its not called that at all.
if i can find the proper code i may be able to order one
503E GTCC / IMSA TURBO ENGINE WITH INTAKE MANIFOLD REBUILT $17,500.00
503E COMPLETE REBUILDABLE BLOCK AND HEAD $8,500.00
503E PARTS AVAILABLE CALL
scope wrote:Mr Revhead wrote:same.....
you can order them from that site. as seen here http://www.toysport.com/webpages/WebUpd ... 202002.htm
no_8wire wrote:pretty good price I think...What else could you buy for that price that has 1150 hp...at 10000 RPM!![]()
