THA SHZ wrote:hey chris pm evil si and he will be able to help u out dude
Adamal wrote:THA SHZ wrote:hey chris pm evil si and he will be able to help u out dude
Yea, Evil Si is a man that loves goats.
cr1mnl wrote:Adamal wrote:Yea, Evil Si is a man that loves goats.
agreed
GTCRSHR wrote:me up some wheel adaptors/spacers ?
im after 4x100 to 4x 100 with a width of 40mm
Quote from http://www.lvvta.org.nz/Wheels&Tyres.pdf wrote:2.5 WHEEL SPACING AND ADAPTION REQUIREMENTS
Spacer requirements for all wheels
2.5(1) A wheel spacer fitted to a low volume vehicle between the wheel
and hub assembly, other than that fitted as original equipment by
a high volume vehicle manufacturer, must:
(a) have a maximum spacing of each wheel away from the hub
surface of 20 mm;and
(b) be set-screwed or attached by another secure method to either
the wheel or hub face; and
(c) be manufactured from a solid block of suitable material;and
(d) have two machined or die-cast surfaces that are parallel, and
contain minimal indentations or irrgularities; and
(e) be fitted as to ensure the wheel locates snugly over the hub
spigot so that the hub carries the weight of the wheel assembly
instead of the wheel studs, or were there is a mis-match
between the hub spigot and the wheel centre, a close tolerance
fit center bore locator must be provided;and
(f) maintain, with the spacer fitted, not less than the minimum
required amount of wheel stud or bolt engagement specified
in 2.4(4)
Users browsing this forum: No registered users and 34 guests
