Who here can machine... NOW WITH QUESTION
Postby GTCRSHR » Wed Feb 08, 2006 3:29 pm
me up some wheel adaptors/spacers ?
im after 4x100 to 4x 100 with a width of 40mm
Nothing to see here ...
GTCRSHR
Postby Ako » Wed Feb 08, 2006 3:49 pm
Well good effort on making everyone look at your posts :lol:
Ako
Postby GTCRSHR » Wed Feb 08, 2006 4:20 pm
thank you :oops:
GTCRSHR
Postby Andy7447 » Wed Feb 08, 2006 4:46 pm
yea i kan if you want to send me some plate or i supply
1989 Celica GT-FOUR
Andy7447
Postby THA SHZ » Wed Feb 08, 2006 6:28 pm
hey chris pm evil si and he will be able to help u out dude 8)
THA SHZ
Postby Adamal » Wed Feb 08, 2006 7:31 pm
THA SHZ wrote:hey chris pm evil si and he will be able to help u out dude 8)
Yea, Evil Si is a man with talent.
Postby GTCRSHR » Sat Feb 11, 2006 1:55 pm
any one else ?
GTCRSHR
Postby cr1mnl » Sat Feb 11, 2006 4:20 pm
Yea, Evil Si is a man that loves goats.
agreed :!: :D
http://toyspeed.blakjak.net/profiles/profile.php?id=708
Horsepowers for bragging, Torques for dragging...
www.ology.co.nz
cr1mnl
Postby THA SHZ » Sun Feb 12, 2006 5:04 pm
cr1mnl wrote:
Adamal wrote:Yea, Evil Si is a man that loves goats.
agreed :!: :D
haha niceone brad , do u still have the photos of him and that goat up on the mountain ? :lol:
THA SHZ
Postby vvega » Sun Feb 12, 2006 6:34 pm
GTCRSHR wrote:any one else ?
yeap
v
vvega
Postby GTCRSHR » Sun Feb 12, 2006 6:36 pm
yeap
v
you can ?
im just waiting to hear back from evil_si and see what he can come up
GTCRSHR
Postby vvega » Sun Feb 12, 2006 6:37 pm
yeap get back to me when ever
v
vvega
Postby GTCRSHR » Thu Feb 16, 2006 7:06 pm
Bump, any one else
do people not want money :?:
GTCRSHR
Re: Who here can machine...
Postby astrae » Thu Feb 16, 2006 7:24 pm
GTCRSHR wrote:me up some wheel adaptors/spacers ?
I've just got 5mm spacers installed and certed. The law says you can only have upto 20mm.
you doing it legally?
Quote from http://www.lvvta.org.nz/Wheels&Tyres.pdf wrote:2.5 WHEEL SPACING AND ADAPTION REQUIREMENTS
Spacer requirements for all wheels
2.5(1) A wheel spacer fitted to a low volume vehicle between the wheel
and hub assembly, other than that fitted as original equipment by
a high volume vehicle manufacturer, must:
(a) have a maximum spacing of each wheel away from the hub
surface of 20 mm;and
(b) be set-screwed or attached by another secure method to either
the wheel or hub face; and
(c) be manufactured from a solid block of suitable material;and
(d) have two machined or die-cast surfaces that are parallel, and
contain minimal indentations or irrgularities; and
(e) be fitted as to ensure the wheel locates snugly over the hub
spigot so that the hub carries the weight of the wheel assembly
instead of the wheel studs, or were there is a mis-match
between the hub spigot and the wheel centre, a close tolerance
fit center bore locator must be provided;and
(f) maintain, with the spacer fitted, not less than the minimum
required amount of wheel stud or bolt engagement specified
in 2.4(4)
astrae
Postby GTCRSHR » Thu Feb 16, 2006 8:12 pm
well i was hoping to ...
but after reading that doesnt seem like i can get it certed ...
cheers for that time to have a bit of a rethink
Does any one have any alternative ideas?
GTCRSHR
Postby soopachargen » Thu Feb 16, 2006 8:25 pm
what about keeping the 20mm but going to a different stud pattern?? say something rear wheel drive so that u have a wider range of offsets available?? I'm guessing through your past posts that you've widebodied your corolla and need wheels to fill the guards?
When in doubt, down and out.
soopachargen
Postby GTCRSHR » Thu Apr 20, 2006 4:43 pm
hi guys,
this guy is the person you want to deal with in regards to spacers /adapters
http://www.trademe.co.nz/Members/Listin ... ber=494852
mine arrived today, very happy 8) 8) 8) 8)
GTCRSHR
Users browsing this forum: Bing [Bot] and 17 guests
