Rusty rust rust rust
Postby ollieboy » Fri Apr 11, 2008 4:33 pm
I was having a fiddle with my MR2 today and a piece fell off along the bottom of the doorsill. It did literally fall off, just dropped from the car. I was quite gutted because it revealed a gaping wound filled with what looks like space invader.(That old filling for homes, not the spacies game)
All I can see in my mind is huge amounts of cost to fix, which would piss me off as I probably can't afford it without dipping into my savings.
For the record, when I purchased the car I inspected this area and it was smooth as and did not look at all like there would be rust under there.
What would your suggestions be Toyspeed? To just bog it up? Or get it professionally fixed?
As an interim measure I have blasted it with heaps of fish oil to stem any further destruction.
Also, I discovered this about an hour ago and have been drinking beer ever since and whoring the internet - it has affected me greatly.
Cheers Toyspeed.
Ollie
Edit: That other bit of flaking to the left of the main patch was where I picked away with a screwdriver to try and gauge the coverage of rust.
ollieboy
Postby Bling » Fri Apr 11, 2008 4:49 pm
bogging it will not help anyone, as you just found out :(
looks like a pro job to me, f**k thats a hole aye!!! 8O :cry:
i'd grind the whole area to see how far it stretches, then look at getting it priced up with it all exposed.
Thats one very dodgy "repair" I have to say
Postby Snoozin » Fri Apr 11, 2008 5:00 pm
That's awesome! One time we used space invader and newspaper to repair a sill on a Datsun Sunny. I bet it looks like that now.
Replace with steel. Unfortunately that's a major, space invader absorbs moisture so I'd be cutting a decent chunk out of that to see if it's affected below the outer skin at all :?
Best of luck!
Snoozin
Postby ollieboy » Fri Apr 11, 2008 5:12 pm
Yeah, I thought it must be a job for a pro.
This really isn't what I need. :lol:
I guess I will have to ring around and find a place to get this looked at. Any good places you know of?
ollieboy
Postby Bling » Fri Apr 11, 2008 5:12 pm
I've heard of someone bogging over a loaf of bread, certainly wouldn't admit to that if it was me tho :lol:
Postby GTCRSHR » Fri Apr 11, 2008 5:14 pm
dam ... that is bad
grind all the bad metal out get rid of that space invader and weld new stuff in,
then sand the whole sill down and POR 15 it
that space invader shit will be a pain in the arse to get out
where abouts are you ? in auckland ? peter hendrix in mt wellington may be able to help you out
Nothing to see here ...
GTCRSHR
Postby method » Fri Apr 11, 2008 5:18 pm
Epoxy the bit that fell off back on :lol:
PICS UPDATED DAILY
method
Postby Alex B » Fri Apr 11, 2008 5:20 pm
Basicly, what you brought is an AW11. Cut it out, see how bad it is, if its too bad, look at reshelling the car. Take carpets out etc too, check the whole thing for rust, dont want to get that fixed and find other parts have cancer too. :x :evil:
Postby ollieboy » Fri Apr 11, 2008 5:28 pm
The rest of the car is fine aye, over the last few months I have had it off the road and took time during that to remove the whole interior and check everything. Thats kinda why I'm so disappointed at this.
Method: I was considering that to tell the truth, out of sight, out of mind. :lol:
ollieboy
Postby Rick » Fri Apr 11, 2008 5:36 pm
I would also be looking how it rusted in the first place, it will be a most likely that it has been caused by a water leak which will be a 99% chance that has also been caused by rust. Try and find how the water is getting in.
Postby ollieboy » Fri Apr 11, 2008 5:39 pm
I would say it rusted originally because it's an AW11 and thats a factory option. :P
ollieboy
Postby Jdawg » Fri Apr 11, 2008 5:42 pm
Lol, it looks like the spider web is stopping the rest from falling off
Jdawg
Postby ollieboy » Fri Apr 11, 2008 5:54 pm
Ok, I just looked in the Yellow pages and found a few rust removal places, there was one 'New Brighton Rust removal and Budget Tyres.' I didn't like the sound of that tbh.
I rang a guy at a place called 'ACR corrosion repairs' I think its called. I gave him a detailed description and he has seen this before apparently so gave me a rough estimate on the phone which is so much better sounding then what I envisioned. Top guy.
ollieboy
Postby Snoozin » Fri Apr 11, 2008 5:57 pm
Take it in and show him, I'd say a phone quote would be about as accurate as a blind man playing darts.
Snoozin
Postby ollieboy » Fri Apr 11, 2008 5:59 pm
Oh yeah, I'm going in to show him as well but he gave me an estimate on what it would cost at the worst of the worst which I was happy with. I'm not silly enough to rely solely on that though :wink:
ollieboy
Postby Emperor » Fri Apr 11, 2008 6:01 pm
Snoozin wrote:Take it in and show him, I'd say a phone quote would be about as accurate as a blind man playing darts.
Agreed!!
Cant remember what it was, but rang up for a quote, and thought sweet, got olds to drop it in while I was at work.. Went in to pay bill after. Almost twice what I was quoted!!
Emperor
Postby Dell'Orto » Fri Apr 11, 2008 6:49 pm
It wont be that hard to fix, just a matter of grinding it all back to see how bad it is then plating it. I had a MK2 Escort with much much worse sills than that.
Postby Truenotch » Fri Apr 11, 2008 8:02 pm
Thats still mint :P , just bog it up and wait for 6 months. Then fix it propperly. That gets rid of the need for an angle grinder cause the water cuts it out for you :o ... well thats what I did anyway, just makes it worse. Not that hard to do propperly.
Truenotch
Postby Mr Revhead » Fri Apr 11, 2008 8:11 pm
take off the trim on the rear of the rear pillar
i think you will find a hole there.
AW11s rust under that trim, the resulting hole leaks water inside the frame, and rusts out where you just found your grand canyon.
its an AW11 it IS rusting in other places. thats what they do.
Postby ollieboy » Fri Apr 11, 2008 8:20 pm
I can't seem to see anything. Is it at the very bottom in the corner? Or am I looking in the wrong place?
ollieboy
