Mr Revhead wrote:usually bolts
that break off when they reach the correct torque.
a b**tard to remove, easy to install
whynot wrote:Do you even have to remove the entire barrel??
I have done a few old vechicles and there is usually a trick to just get the guts of the barrel out and then click a new one in. the key does need to work for most of them though but mabey a lock smith can do it quick enough and cheap enough to make it worth while
snwtoy wrote:Mr Revhead wrote:usually bolts
Those would be the ones... where would mr Turcel find replacements?
Mr Revhead wrote:you do if its $&#$%!
Mr Revhead wrote:i mean the whole barrel assembly
mates WRX was broken into and they munted the whole barrel, not just the cylinder, trying to start it. obviously n00bs!
that was a mission as we had to pull the thing apart in the middle of a car park
holden_fan2005 wrote:If it's any help my old ladys rav 4 ign barrel was locked into acc. We pushed a little gold pin underneath and the lock part came compeltly out and we could start it with a small screwdriver until we got another lock part that day.
Easy as
