who works with haltech ecus
Postby escortman » Mon Jul 20, 2009 7:12 pm
mates 10sec vr4 needs the hot and cold map setting on the ecu remaped,
where in auckland is a good place for this to be done?
4x4 toyota blizzard offroader
escortman
Postby strx7 » Mon Jul 20, 2009 8:24 pm
what do you mean by hot and cold map??
Postby tsoob » Tue Jul 21, 2009 9:52 am
strx7 wrote:what do you mean by hot and cold map??
my guess is the start up map and the main boost map.
haltech +4wd? not 100% mate, try gary capper performance in pukekohe. i know he does a LOT of work with evo's etc. not sure of his number but its in whitepages or yellow.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby MR2BOY23 » Tue Jul 21, 2009 10:05 am
Spec2?
They built that 9second vr4 in nzpc
MR2BOY23
Postby strx7 » Tue Jul 21, 2009 10:31 am
There is a fuel / coolant correction map which handles the enrichment when the engine is cold and it then pulls out enrichment fuel as it gets closer to operating temp.
this 'hot map/cold map' is all the same correction map, unless they are talking about something else.
Hitech Motorsport in Drury are a Haltech Agent so should be able to sort out whatever the issue is.
Postby escortman » Tue Jul 21, 2009 6:04 pm
yeh im not to sure what he mean by hot n cold, but cheers for them places
escortman
Postby 4EFTE » Tue Jul 21, 2009 6:25 pm
if its the old vr foe vr4, garry capper did the tune on it at the moment.
4EFTE
Postby slighty_looney » Sun Jul 26, 2009 6:38 pm
sochi at st-hi tec has a 4wd dyno, im pretty sure andre simons from STM flys up there for tunning on sochi's dyno every now and then, done a few spec evos on the dyno so that might be a start
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby Infinite » Sun Jul 26, 2009 6:55 pm
and who has a 4wd dyno in hamilton?
Lots
Infinite
hm
Postby ezy10s » Sun Jul 26, 2009 7:24 pm
that fuel coolant map is pretty simple to organise- only thing is that you basically need to do it over a few mornings- so you are adjusting it when its first warming up. once its warm thats it until the next morning
Probably best doing it yourself over a week or so.
Member #244
ezy10s
Re: hm
Postby strx7 » Sun Jul 26, 2009 9:35 pm
ezy10s wrote:that fuel coolant map is pretty simple to organise- only thing is that you basically need to do it over a few mornings- so you are adjusting it when its first warming up. once its warm thats it until the next morning
exactly, you only get a few mins to play with it everytime the car is started from cold.
