mates 10sec vr4 needs the hot and cold map setting on the ecu remaped,
where in auckland is a good place for this to be done?
strx7 wrote:what do you mean by hot and cold map??
tsoob wrote:strx7 wrote:what do you mean by hot and cold map??
my guess is the start up map and the main boost map.
haltech +4wd? not 100% mate, try gary capper performance in pukekohe. i know he does a LOT of work with evo's etc. not sure of his number but its in whitepages or yellow.
ezy10s wrote:that fuel coolant map is pretty simple to organise- only thing is that you basically need to do it over a few mornings- so you are adjusting it when its first warming up. once its warm thats it until the next morning
Probably best doing it yourself over a week or so.
