Value of ceramic CT20b?
Postby sergei » Fri Apr 13, 2012 1:11 pm
Need a reality check:
What is a value of a ceramic CT20b in good condition?
Postby MR2SIK » Fri Apr 13, 2012 1:44 pm
Some dreamers out there list them for around $800, wouldn't I
Imagine anyone paying more than $600-650 for one. They're getting on a bit now.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby sergei » Fri Apr 13, 2012 5:12 pm
Is there much demand for them? I would think it is best upgrade for CT26 (value for money), and since there are quite a few of gen2 3SGTE around, they would sell like hotcakes?
Postby Dell'Orto » Fri Apr 13, 2012 6:24 pm
Yeah always demand for them, $600 would sell it quickly. Could probably hold out for $800 if you felt the need.
Postby Al » Fri Apr 13, 2012 6:38 pm
$600 for a ceramic.
Add maybe $150-$200 if its a steel wheeler.
Al
Postby sergei » Fri Apr 13, 2012 9:46 pm
Thanks, anyone interested in one ;) :lol:
Postby Dell'Orto » Fri Apr 13, 2012 9:49 pm
Post on the MR2 owners club, someone will snap it up.
Postby sergei » Fri Apr 13, 2012 9:55 pm
Dell'Orto wrote:Post on the MR2 owners club, someone will snap it up.
Thanks, will do, but I have to see it first (and most importantly the engine it came with). I am going to pick up the pallet tomorrow, that will be a lot of fun....
Postby MR2SIK » Sat Apr 14, 2012 4:03 pm
What are the KM's on it?
MR2SIK
Postby sergei » Sat Apr 14, 2012 4:39 pm
MR2SIK wrote:What are the KM's on it?
133k.
Postby MR2SIK » Sat Apr 14, 2012 5:26 pm
Could be keen if I can persuade the mrs to loosen the purse strings with the wedding fund :lol:
MR2SIK
Postby Bling » Sat Apr 14, 2012 5:30 pm
In other words, you got no show :lol:
Postby Heylin » Mon Apr 23, 2012 5:53 pm
133K, so has a useable life of 50-60K left depending on how its been treated.
$550-$650 is pretty realistic \ fair
FYI, I got $900 for mine with 20,000 kms on it, 2 years ago.
Heylin
Heylin
Postby kim0663 » Tue Apr 24, 2012 2:21 am
Heylin wrote:133K, so has a useable life of 50-60K left depending on how its been treated
Just because your turbo died at 180kms, does not mean that most turbos will last this long. 180kms on any turbo is exceptionally good milage I think.
As far as I know, a turbo could be dead at 130kms too.
Mr2 GT-S
330ci M
kim0663
Postby sergei » Tue Apr 24, 2012 9:05 am
or 330k ;).
My drive car (ST205) has already 175k, and there is no sign of turbo wear (it does not even whine). My ST165 original turbo done 200k and there was no sign of wear (no shaft play, or oil in the housings).
Life time of a turbo is a speculation. Most important factor to turbo failure is coke (sludge). If the engine is serviced regularly with good oil, and it does not run stupid amount of boost, there are no reasons for turbo failure at 130k or even 230k.
In most cases, after 150k people give up on regular servicing and that leads to multiple problems including turbo failure.
Postby Heylin » Tue Apr 24, 2012 2:01 pm
This was based on my CT26
- 5 year Full service history since new (80,000 kms)
- 3 years of unknown history (30,000 kms
- 10 years under me (110,000kms) good oil and regular changes, warm downs.
Heylin
Heylin
Postby sergei » Tue Apr 24, 2012 2:56 pm
All it takes is to skip 1 service, on already prolonged service periods (eg: 15k service period vs 5k that is required for Turbo).
Postby ~SlideWays~ » Tue Apr 24, 2012 3:40 pm
Are CT20b's that good that you can't just get a dirty old CT26 rebuilt with better designed exh and comp wheels?
~SlideWays~
Postby sergei » Tue Apr 24, 2012 4:11 pm
~SlideWays~ wrote:Are CT20b's that good that you can't just get a dirty old CT26 rebuilt with better designed exh and comp wheels?
Most likely you can. CT20b is good because it is more or less a decent turbo (unlike CT26) and is a bolt on for Gen2. You can get better results with turbos from dark side (Subaru/Mitsubishi) if your ECU allows, but those are not bolt-ons and at least require a spacer.
But generally speaking with CT20b at 1bar with Gen1/2 stock engine, and stock ECU you can expect ~ 170-180kW at the 4 wheels with minimal mods, compared to CT26 ~140kW at the 4 wheels if you are lucky (same boost).
Postby ~SlideWays~ » Tue Apr 24, 2012 4:40 pm
Do you know if they spool better or is it all top end?
~SlideWays~
