Dell'Orto wrote:Post on the MR2 owners club, someone will snap it up.
Heylin wrote:133K, so has a useable life of 50-60K left depending on how its been treated
kim0663 wrote:Heylin wrote:133K, so has a useable life of 50-60K left depending on how its been treated
Just because your turbo died at 180kms, does not mean that most turbos will last this long. 180kms on any turbo is exceptionally good milage I think.
As far as I know, a turbo could be dead at 130kms too.
~SlideWays~ wrote:Are CT20b's that good that you can't just get a dirty old CT26 rebuilt with better designed exh and comp wheels?
sergei wrote:~SlideWays~ wrote:Are CT20b's that good that you can't just get a dirty old CT26 rebuilt with better designed exh and comp wheels?
Most likely you can. CT20b is good because it is more or less a decent turbo (unlike CT26) and is a bolt on for Gen2. You can get better results with turbos from dark side (Subaru/Mitsubishi) if your ECU allows, but those are not bolt-ons and at least require a spacer.
But generally speaking with CT20b at 1bar with Gen1/2 stock engine, and stock ECU you can expect ~ 170-180kW at the 4 wheels with minimal mods, compared to CT26 ~140kW at the 4 wheels if you are lucky (same boost).
