Removing rods from pistons?
Postby Adoom » Tue Nov 20, 2012 12:37 pm
I want to separate some rods from pistons in a CA18DET.
It has circlips at either side of the gudgeon pin.
After removing the circlips, should the pin just slide out? It doesn't seem to want to move...
The manual does not say anything about using a press to remove them. :?
All it says is to heat them in an oil bath to 60-70 degrees.
I don't want to put a pot of oil on the gas stove....Can I just use boiling water?
Does the expansion from heat make them easier to remove? Will I still need to have them pressed out?
Adoom
Postby Shrike » Tue Nov 20, 2012 12:43 pm
I use a press when I remove my pins just something Ive always done
Why dream it when you can live it
Shrike
Postby Adoom » Tue Nov 20, 2012 12:45 pm
Shrike wrote:I use a press when I remove my pins just something Ive always done
Could I use the vice as a press? With suitable support for the piston of course.
Adoom
Postby Bazda » Tue Nov 20, 2012 1:17 pm
I slightly heat the piston on the underside where the meat is around the gudgen. You only need to heat them a little and the pins come straight out.
Re: Removing rods from pistons?
Postby Bling » Tue Nov 20, 2012 1:37 pm
Adoom wrote:I don't want to put a pot of oil on the gas stove....
Why not? 60-70 degrees is piss all temp. My deep fryer goes to 190.
Postby Adoom » Tue Nov 20, 2012 1:37 pm
Bazda wrote:I slightly heat the piston on the underside where the meat is around the gudgen. You only need to heat them a little and the pins come straight out.
How much is "a little"?
Hair drier?
Paint stripping heat gun?
Gas welder?
Adoom
Postby Adoom » Tue Nov 20, 2012 1:39 pm
Gas stove... flames... a bunch of oil... seems like a bad combination.
Adoom
Postby Shrike » Tue Nov 20, 2012 1:40 pm
if your in tawa this weekend your welcome to use my press I have had no damage when using it on any of my pistons except the one I forgot to remove the circlip on
Shrike
Postby Bling » Tue Nov 20, 2012 1:53 pm
Adoom wrote:Gas stove... flames... a bunch of oil... seems like a bad combination.
Oil boils at a lot higher temp than water. I don't think you'll have any issues. I'm a professional :lol: But seriously, I don't see the danger. People use pots to deep fry things all the time. Deep frying will be MUCH higher temp than what you need.
Just don't add a cup of water when the oil is up to temp.....
Postby Adoom » Tue Nov 20, 2012 2:05 pm
Shrike wrote:if your in tawa this weekend your welcome to use my press I have had no damage when using it on any of my pistons except the one I forgot to remove the circlip on
Thanks. I will keep it in mind if the oil does not work.
Adoom
Postby Bazda » Tue Nov 20, 2012 2:11 pm
Gas torch. Heat each part holding the pin for around 5-8s long.
Postby Rick » Tue Nov 20, 2012 5:07 pm
I just heated up water on a gas stove, works fine, I have also used a heat gun but the water is better for even heat distribution.
Postby mjrstar » Tue Nov 20, 2012 5:28 pm
chuck them in the oven at 120 on fan bake for 20-30 mins, this should give you the desired amount of heating...
no messy pots of oil etc..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby rollaholic » Tue Nov 20, 2012 7:06 pm
mjrstar wrote:chuck them in the oven at 120 on fan bake for 20-30 mins, this should give you the desired amount of heating...
this.
just dont let the missus / mum find out
Postby Elmo » Tue Nov 20, 2012 7:13 pm
this.
We usually just hit the pistons with the steam cleaned for a few seconds, or just dunk the piston in hot water (from the steam cleaner). I wouldnt use the oven idea as you are giving the pin as much time to heat up. The idea is with water/oil that the ally piston heats up and expands considerably faster than the steal pin, but 20-30 mins in an oven will warm everything up.
Elmo
Postby Grrrrrrr! » Tue Nov 20, 2012 8:41 pm
30 mins in oven will heat everything up just like an oil bath will. Aluminium expands more than steel so pin comes out easy.
Grrrrrrr!
Postby Adoom » Wed Nov 21, 2012 7:46 pm
I boiled up a pot of water and stuck each piston in for 20seconds.
The pins were easy to push out, by hand, with a long bolt. Fecking hot if you touch the pin or piston :roll:
Adoom
Postby evil_si » Wed Nov 21, 2012 9:54 pm
Most pistons will come apart using hot water just from the tap,
I wouldnt press them if i intended to reuse them
Otherwise a few seconds of gas heating on the back of the skirt works well
evil_si
Postby Bazda » Fri Nov 23, 2012 8:46 am
I also would not press them.
Heat them in any of the ways above, which ever is easier for you depending on what equipment you have available.
