Crankshaft pulley holder tool
Postby solitaire » Wed Jan 09, 2013 10:51 am
Hi all,
In need of one of these, Mark is kindly checking Toyota but I would like to have a backup if that is a no go - i don't want to flick the starter as i have read horror stories about stuff breaking.
Anyone know of a please that sell these? Trying to do up the bolt to the right torque
Dave
AE92, KZJ120, KDJ120
solitaire
Postby Dell'Orto » Wed Jan 09, 2013 12:17 pm
If you've got a welder and have a bit of steel lying around its not hard to make one...I did for my 3SGTE crank pulley.
Postby DeeCee » Wed Jan 09, 2013 1:09 pm
This is the one I built:
GT Four Adovansu
DeeCee
Postby KE20 » Wed Jan 09, 2013 2:53 pm
i put a giant screw driver against the flywheel in the teeth and that seems to hold it fine.
Garage Dori
KE20
Postby ee904age » Wed Jan 09, 2013 5:21 pm
Not going to help you with the engine in the car but in the past I've bolted a short length of chain from a bellhousing bolt to clutch pressure plate (gearbox off obviously).
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby fangsport » Wed Jan 09, 2013 6:00 pm
ee904age wrote:Not going to help you with the engine in the car but in the past I've bolted a short length of chain from a bellhousing bolt to clutch pressure plate (gearbox off obviously).
i have a few slotted and cranked bits of plate for removing flywheels.
the factory Toyota lifting hooks work well !!
fangsport
Postby solitaire » Fri Jan 11, 2013 2:42 pm
Have not got the time or raw materials to build a tool for this, the wife has spat the dummy - wants me to "just sort it, spend a couple of hundred and get it done"
so - I could buy a tool to hold the crank $160.
Or I could buy a air ratchet impact gun thing, a proper one that will do it up easily tight enough (181ftpnd) for a bit more.
Question is: will a decent air ratchet do the job? (providing air compressor is up to scratch)
solitaire
Postby Grrrrrrr! » Fri Jan 11, 2013 2:54 pm
If the sump isn't on the motor yet, jam a wooden/plastic handle from a hammer or whatever between the crank and the block to stop crank from turning. If the sump is on, have you got enough threebond to redo it?
Grrrrrrr!
Postby phoenix » Fri Jan 11, 2013 2:59 pm
Remove inspection cover to gain access to the flex plate, jam large flathead screwdriver into gear and against bell housing while you tighten crank bolt.
phoenix
Postby Mr Revhead » Fri Jan 11, 2013 3:10 pm
You don't really want to do it up with a rattle gun. How do you know how tight it is?
Can see you pinging off the head!
Postby solitaire » Fri Jan 11, 2013 3:11 pm
Engine is in car unfortunately, i tried the inspection cover but im loathed to do it with 181ftpnds and having the torque converter just behind it, ive dodged one bullet already on this - so the ratchet is a no go is that right?
solitaire
Postby Mr Revhead » Fri Jan 11, 2013 3:18 pm
This is why you should never buy an auto :P
Postby neo » Fri Jan 11, 2013 3:19 pm
I done up a few with the rattlegun, nothing has ever snapped or come off...
I have a decent rattlegun however, and I always locktite the bolt.
neo
Postby limbo » Fri Jan 11, 2013 3:20 pm
The easiest way I know how to do it is to remove the starter motor, on my car takes about 30-60min, then I used an old big end bearing with the ends fitted nicely against the fly wheel teeth with the round side nicely jammed against the bell housing.
Then I used a torque wrench to tighten the bolt, I had to hire one for like $20 as I didnt have one that went up to 265N.m, hired torque wrenches are also calibrated regularly so that is a bonus. 265N.m is a serious amount of torque so I wouldnt play about with rattle guns or guess work.
The whole job should take about 1 to 2 hours with most of that work removing and installing the starter motor.
You have already spent much longer thinking about it so just get out there and do it
limbo
Postby solitaire » Fri Jan 11, 2013 3:41 pm
Getting at the starter motor is a prick of a job on a 1uz as far as i can tell.
So consensus is sst and torque it up?
I really dont want to risk breaking anything, had a really near miss and just want to do it right and have my reliable old celsior back!
solitaire
Postby Bling » Fri Jan 11, 2013 4:33 pm
SST if you can't rangi something up to do the same job. DeeCee had a perfect example of a simple alternative to the SST that works and won't do any damage. Do you have an image of the SST required?
Postby phoenix » Fri Jan 11, 2013 5:09 pm
Removing the starter to jam the ring gear will achieve the same as going through the inspection cover (except taking a hell of a lot longer)
It sounds like you're set on locking the pulley though, so are any of the people who've rangi'd one up in your vicinity?
phoenix
Postby Dell'Orto » Fri Jan 11, 2013 5:22 pm
If the spending advisor has given the go ahead to spend money I'd just take it to a mechanic and make it their problem :lol:
Postby Lloyd » Fri Jan 11, 2013 5:43 pm
Mr Revhead wrote:You don't really want to do it up with a rattle gun. How do you know how tight it is?
Spoken like a true parts guy :P
The rattle gun really only has 2 setting: Tight enough and undo
Get in behind the cover and use a lever bar/whatever to lock up the converter. Worst case just buy some loctite and do it up to however tight you can.
Postby solitaire » Fri Jan 11, 2013 5:45 pm
Dell'Orto wrote:If the spending advisor has given the go ahead to spend money I'd just take it to a mechanic and make it their problem :lol:
Thing is if I take it to a garage all they will do is do it up with a rattle gun... 50% of the reason i do this stuff myself is because I have never found a trustworthy mechanic who actually does it properly - they forget stuff or do it up too tight or forget to connect something... its a hassle - not as much of a hassle as this mind you - will get them to do the big stuff in future.
was hoping to justify a new rattle gun but if thats not the way to do it ill get the sst - it will take me 4 hours to get the raw materials and cut and weld a diy version anyway so i may as well buy it.
Cheers for the advice as always mate :D
solitaire
