ee904age wrote:Not going to help you with the engine in the car but in the past I've bolted a short length of chain from a bellhousing bolt to clutch pressure plate (gearbox off obviously).
Mr Revhead wrote:You don't really want to do it up with a rattle gun. How do you know how tight it is?
Thing is if I take it to a garage all they will do is do it up with a rattle gun... 50% of the reason i do this stuff myself is because I have never found a trustworthy mechanic who actually does it properly - they forget stuff or do it up too tight or forget to connect something... its a hassle - not as much of a hassle as this mind you - will get them to do the big stuff in future.Dell'Orto wrote:If the spending advisor has given the go ahead to spend money I'd just take it to a mechanic and make it their problem
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 55 guests
