CozmoNz wrote:barryogen wrote:yes it could be re-worked with lower compression, but well, thats not going to overly help, the 2zz doesn't like anymore than about 10PSI before they start throwing pistons through blocks sideways.
That would be because of the high compression....
actually, as I understand it, it is because the cylinder walls are only 3mm(might have been 5?) and 1mm(on either side) is the sleeve that the pistons are in...
I was meaning thrown sideways as in from one cylinder to the neighbouring one, +ve pressure on one side, -ve pressure on the other side, only thing holding them apart being very thin aluminium(and the sleeve), from what I've read...
anyway, 10psi is a whole 4psi above where this kit sits factory... the greddy kit does 8psi and isn't intercooled at all
