yay for me
Postby barryogen » Thu May 04, 2006 5:04 pm
CozmoNz wrote:
barryogen wrote:yes it could be re-worked with lower compression, but well, thats not going to overly help, the 2zz doesn't like anymore than about 10PSI before they start throwing pistons through blocks sideways.
That would be because of the high compression....
actually, as I understand it, it is because the cylinder walls are only 3mm(might have been 5?) and 1mm(on either side) is the sleeve that the pistons are in...
I was meaning thrown sideways as in from one cylinder to the neighbouring one, +ve pressure on one side, -ve pressure on the other side, only thing holding them apart being very thin aluminium(and the sleeve), from what I've read...
anyway, 10psi is a whole 4psi above where this kit sits factory... the greddy kit does 8psi and isn't intercooled at all 8O now that would worry me.
barryogen
2ZZ Guru in training
Postby MasCam » Thu May 04, 2006 9:33 pm
Good on you for doing your own thing instead of following the masses.
Everyone is always going on about how turbo's are always better but not everyone is looking for the same thing. Go the supercharger!!!
Oh by the way way how the hell are you going to put up with that noise all the time when you complained about your exhaust sounding like a 20V. Perhaps a switch to turn of the supercharger?? could also come in handy if the cops try to get you for excessive noise.... Not me officer I'm just driving this nice corolla, it must of been someone else, why of course I can give it a rev for you :lol: :lol:
Oh and just to beat the rush, when it is done I call SHOTGUN at the first meet.
MasCam
Postby barryogen » Fri May 05, 2006 8:55 am
MasCam wrote:Oh by the way way how the hell are you going to put up with that noise all the time when you complained about your exhaust sounding like a 20V. Perhaps a switch to turn of the supercharger?? could also come in handy if the cops try to get you for excessive noise.... Not me officer I'm just driving this nice corolla, it must of been someone else, why of course I can give it a rev for you :lol: :lol:
The noise is only there when you push the car hard, it is on an electric clutch, and can be disabled/switched, and the ECU just "gets" it.
mascam wrote:Oh and just to beat the rush, when it is done I call SHOTGUN at the first meet.
ummm, ok then, sounds like a plan.
barryogen
Postby AJz » Fri May 05, 2006 11:07 pm
Buy one of these man, bolts straight up, extra 300hp gain !!!
I had vtax :(
AJz
Postby Vodka » Sat May 06, 2006 1:12 am
man I have two on civic and it goes hard au
>>>>>Lunchie says: i like honda's<<<<<<<<<<<
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1633
Vodka
Postby Lunchie » Mon May 08, 2006 3:28 am
AJz wrote:Image
nar man thats way too low i heard you can line 3 up in a line and run 9's au!!!
"The air is heavy with antisipation as cozmo revs, drops the clutch and...... stalls with the hand brake on"........ "cozmo's hand brake one, cozmo 0"
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1201 <----Click to see real POWER :P
Lunchie
Postby barryogen » Mon May 08, 2006 10:10 am
Lunchie wrote:
AJz wrote:Buy one of these man, bolts straight up, extra 300hp gain !!!
an extra 300... hard bro... chur chur
9's? I can already do 8's* thanks to those orsome electrical supercharger, the turbo sounder, and the "greddy style" exhaust tip that I got off trademe
Vodka wrote:man I have two on civic and it goes hard au
yeah I knew you had more than that shitty little B18C in there...
*times 2
barryogen
Postby MasCam » Mon May 08, 2006 5:54 pm
On a slightly more serious note I read today that the lotus exige (elise with a roof) is now available with a supercharger on its 2zz engine. I wonder how much they charge for the lotus embosed cam covers??
MasCam
Postby barryogen » Mon May 08, 2006 6:11 pm
MasCam wrote:On a slightly more serious note I read today that the lotus exige (elise with a roof) is now available with a supercharger on its 2zz engine. I wonder how much they charge for the lotus embosed cam covers??
well a new gearbox for it costs a tad over 11k US last time I checked compared to ~3k for a new one for my 2zz... and supposedly(part number is different, the lotus has an additional 1 on the end, and fits the MRS apparently, although it is expected to be stronger due to the MRS having the 1zz, and the Exige the 2zz*) they are the same as the MRS GB, which is considerably cheaper.
It also looks like there is a slight change with the configuration of the gearbox where they make it so that the GB slots(as in forward rear movement) is slightly angled to assist with cutting down what has been termed "YAMS" by 2zz owners, YAMS stands for "Yet Another Miss Shift", which apparently kills oil pumps, bends valves, cracks blocks# and stuff when the engine skyrockets into high revs very quickly.
*do I read too much?
#sound familiar? it did to me... I didn't do it though, maybe the previous owner did?
oh yeah.. Cam covers... the Toyota ones are $374 as of ~three months ago, I'd imagine that the Lotus ones(it appears to be in two parts like the celica GTS) is a fair bit more.
Lotus
Celica GTS
Although it is hard to tell from that angle.
Also for a comparison have a look at the Pontiac Vibe GTS(I think) as they have a single piece like mine should.
barryogen
Postby AE85coupe » Mon May 08, 2006 10:32 pm
just out of interest, why didn't ya just get a sc14 (or whatever they are) 4agze supercharger put on it?
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby barryogen » Tue May 09, 2006 9:23 am
AE85coupe wrote:just out of interest, why didn't ya just get a sc14 (or whatever they are) 4agze supercharger put on it?
I looked around for one for a while, but the ones(2) I looked at, had a lot of play on the shaft, and didn't seem to turn particuly well, which they should when not attached to anything.
I had considered doing it myself(with a Rotrex SC, looks like a half snail with a pulley instead of the exhaust bit), and yeah I could probably do it a bit cheaper if I did, and it may well end up being like that due to having a bitch of a time trying to get info from the Blitz agents.
barryogen
Postby barryogen » Mon May 22, 2006 2:24 pm
I had an interesting chat with the Mrs over the weekend, it seems that she is fine with me getting this... so thats all good, the only condition is that I have to take her on holiday "somewhere nice"... I hear that Gone is "Nice" :lol:
barryogen
Users browsing this forum: Bing [Bot] and 0 guests
