Engine Bay Gold Heat Reflective shield (Self Adhesive )
Postby Bazda » Mon Jul 18, 2011 12:06 pm
FortuneAuto|Wilwood|Quartermaster|Fidanza|ARP|TRE|MOTUL|MasterPower|RC Injectors|Aeromotive|STD Suspension|Enkei|Rota Wheels|Work Lug Nuts
Reflective Gold foil (heat shield)
I found this type of item quite hard to source in NZ at the temperature rating needed for engine bays. Lots of items sold without adhesive which make it difficult to install.
This product made in USA comes with adhesive! making it REALLY easy for installations.
For many years aeronautical agencies like NASA have used heat reflective gold foil on satellites and various space crafts. Our sourced foil is actually made of 22k gold. capable of reflecting 78% of all radiant heat with continuous operating temperatures of 450 degrees centigrade. The material is metalized polyamide polymer laminated glass cloth with a high temperature pressure sensitive adhesive.
Typical applications include but are not limited to, intercooler pipes, intercoolers, intakes, airboxes, engine covers, coilovers, under trays/floors, seat bottoms, fire walls and bulkheads. The minimum air gap to heat source is just 1mm!
CONSTRUCTION: Metallized polyimide film laminated to glass cloth with high temperature acrylic adhesive protected by a release liner.
FEATURES: Excellent heat reflective characteristics and is easy to install. Withstands 675°F of radiant heat for a minimum of 8 hours
Size: 600mm x 300mm (each sheet)
Price: $65 incl GST
Postby RH9 » Tue Jul 19, 2011 1:20 pm
Hi Barry, so this stuff has "easy peel" self adhesive backing ala double sided tape? Looks like it would work a treat on my R32.
Thanks
Andy
2003 TRD Vitz RS Turbo - 160hp
2000 Toyota Aristo TTE - 490hp
1991 Skyline GTR - 720hp
www.gtr-elite.com
www.sthitec.co.nz
RH9
Postby Bazda » Tue Jul 19, 2011 1:32 pm
RH9 wrote:Hi Barry, so this stuff has "easy peel" self adhesive backing ala double sided tape? Looks like it would work a treat on my R32.
Thanks
Andy
Yes thats correct. Its a double sided tape which has been pre-bonded onto the gold foil. Very easy to install.
If your after some let me know and i'll send you a pm.
Postby pureadrenalin » Tue Jul 19, 2011 2:47 pm
I'm going to need two sheets of this when I drop my engine.
Should be in a couple of weeks when I feel like paying attention to the car again
Duct tape is like the force. It has a light side, a dark side, and it holds the world together
pureadrenalin
Postby Bazda » Tue Jul 19, 2011 3:33 pm
pureadrenalin wrote:I'm going to need two sheets of this when I drop my engine.
Just hit me up!, order is still on its way from USA.
Postby RH9 » Wed Jul 20, 2011 9:53 am
PM sent :)
www.gtr-elite.com
www.sthitec.co.nz
RH9
Postby Bazda » Fri Oct 07, 2011 10:19 am
In Stock now. Only a limited supply!
Postby 1I1 » Mon Jun 25, 2012 3:45 pm
Tried some of this in the weekend - real easy to use!! Just need a nice sharp blade and you're good to go
TRD Clicky >>Here
1I1
Postby Bazda » Mon Jun 25, 2012 4:34 pm
1I1 wrote:Tried some of this in the weekend - real easy to use!! Just need a nice sharp blade and you're good to go
wheres the pics!
Postby 1I1 » Mon Jun 25, 2012 4:37 pm
Bear in mind I suck at applying films which is why theres crinkles - and that the plenum is a horrible shaped piece to try to wrap :oops:
TRD Clicky >>Here
1I1
Postby cat007 » Mon Jun 25, 2012 6:16 pm
Hey Barry
Can you get, or have you got, this sort of thing?
Postby Bazda » Mon Jun 25, 2012 8:47 pm
cat007 wrote:Hey Barry
No. cheaper to use thin sheet alloy over that stuff.
Postby pureadrenalin » Tue Jun 26, 2012 2:11 pm
Barry, can I progress this?
I'll PM you my delivery address.
Could you also flick me some clutch options and prices for a 3sgte MR2.
pureadrenalin
Postby Bazda » Mon Feb 11, 2013 3:55 pm
Finally back in stock!
Postby holden_fan2005 » Mon Feb 11, 2013 6:43 pm
You wouldn't have this type of thing but in tubing? For using on water feeds close to headers etc.
holden_fan2005
Postby Bazda » Mon Feb 11, 2013 7:40 pm
holden_fan2005 wrote:You wouldn't have this type of thing but in tubing? For using on water feeds close to headers etc.
You need Fyre Foil. I dont have that stuff sorry.
Postby cat007 » Tue Feb 12, 2013 7:59 am
I used this weird stuff for a couple of hard brake lines that run close to my waste gate. It's orange and the inside is fluffy. I'll try and get a pic tonight. Apparently it's the shiz.
Postby Bazda » Tue Feb 12, 2013 8:27 am
The orange stuff is not the shiz sorry lol.
I thought it was, put it over my oil lines near the turbo. Did a track day and all my oil lines near the turbo went rock hard!! and even started to burn. The Orange stuff doesnt reflect heat thats the problem.
So I went and got Fyre Foil from USA and this stuff is the shiz! just damn hard to find in NZ.
Id consider bringing it into NZ if people wanted some..
Here is some I found doing a google search:
http://pitstopusa.com/c-136047-fittings ... il-ii.html
Postby 1I1 » Mon Feb 18, 2013 10:13 am
TRD Clicky >>Here
1I1
Postby MrOizo » Tue Feb 19, 2013 3:50 pm
That looks like the Russian Space Station! Maybe get me some soon.
1I1 wrote:Image
MrOizo
Toyspeed Legend
Return to Toyspeed Sponsors
