RH9 wrote:Hi Barry, so this stuff has "easy peel" self adhesive backing ala double sided tape? Looks like it would work a treat on my R32.
Thanks
Andy
pureadrenalin wrote:I'm going to need two sheets of this when I drop my engine.
Should be in a couple of weeks when I feel like paying attention to the car again
1I1 wrote:Tried some of this in the weekend - real easy to use!! Just need a nice sharp blade and you're good to go
cat007 wrote:Hey Barry
Can you get, or have you got, this sort of thing?
Bazda wrote:pureadrenalin wrote:I'm going to need two sheets of this when I drop my engine.
Just hit me up!, order is still on its way from USA.
holden_fan2005 wrote:You wouldn't have this type of thing but in tubing? For using on water feeds close to headers etc.
Bazda wrote:holden_fan2005 wrote:You wouldn't have this type of thing but in tubing? For using on water feeds close to headers etc.
You need Fyre Foil. I dont have that stuff sorry.
cat007 wrote:Bazda wrote:holden_fan2005 wrote:You wouldn't have this type of thing but in tubing? For using on water feeds close to headers etc.
I used this weird stuff for a couple of hard brake lines that run close to my waste gate. It's orange and the inside is fluffy. I'll try and get a pic tonight. Apparently it's the shiz.
