VVt pully
VVt pully
Postby Gx71man » Thu Jan 27, 2005 7:10 pm
i no some one who says his vvt pully is $&#$%. vvt dusnzt work at all. its in a ae101. he dropped it down a gear or so when he was doin 160kmph.
and says it broke or snapped of or summint. what acctual breakes??? is it a cam pully or wat??
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
Postby RedMist » Fri Jan 28, 2005 2:27 pm
Tried to bablefish this one. However there wasn't an Idiot to English translation.
I gather from the text it has something to do with VVT actuation?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby CozmoNz » Fri Jan 28, 2005 3:56 pm
well, it appears the chap is saying his friend, with an ae101 levin / trueno, dropped it down to (4th?) from (5th?) gear.... and broke his vvt pully.
ok, so many things wrong with what you said
A) the Trueno and Levin gearsets can pull 180ish in 4th gear... so *dropping down* a gear, is useless.. even 3rd pulls to around 140-150ish. i doubt he could accidently drop it down to 3rd.... not at that speed. So im assuming here, he went from 5th to 4th.. which is what you would do if passing someone at that sort of speed...
alas
B) that couldnt damage the pull at all... unless you hit excess rpm.. to somehow damage the cam gear setup... which i doubt, youd dick the rest of your engine before a pully got destroyed. how many engines break the crank angle sensor before they damage something else? - and i know its not a Crank angle sensor, but effectly it is attached to the same thing.... all im saying is what rpm would be required before a vvt pully would nuke itself? im thinking 20,000+ rpm? go chuck one on an F1 car and find out when it *fails*.
C) if its stuffed, it will be locked into one location, if its on its way out, it will click.... still work but click... and only get louder until she brakes.... in which you replace it...
so um, wants excactly the problem?
Rayne For President!
CozmoNz
Postby pervert » Fri Jan 28, 2005 3:59 pm
I used to be able to jam my Prelude into third when sitting on cut-out, it got a bit mad. So it could well be he dropped it into third.
pervert
Postby fivebob » Fri Jan 28, 2005 4:04 pm
Could've gone 5th - 2nd 8O
I've done that once on a rental Ford Escort, lots of smoke from the tyres and the tacho needle bouncing off the stops, didn't break anything tough... damm sh*tty Ford gearboxes :(
Postby thaphatty » Fri Jan 28, 2005 4:12 pm
your lucky you didnt centrifuge your clutch 8O
thaphatty
Postby vvega » Fri Jan 28, 2005 10:49 pm
fivebob wrote:Could've gone 5th - 2nd 8O
rentals can do anything and even go places most 4WD off roaders would fair to tread :D
v
vvega
Postby Bling » Sat Jan 29, 2005 11:42 am
CozmoNz wrote:A) the Trueno and Levin gearsets can pull 180ish in 4th gear... so *dropping down* a gear, is useless..
last time i checked 4th did more than 180 (at less than rev cut), so where did u work that one out? or u just making stuff up again? :roll:
Postby AceSniper » Sat Jan 29, 2005 12:08 pm
160 in 3rd is 9000rpm ;)
AceSniper
Postby Bling » Sat Jan 29, 2005 4:48 pm
AceSniper wrote:160 in 3rd is 9000rpm ;)
show off :P must sound nice at 9k :twisted:
Postby CozmoNz » Sat Jan 29, 2005 6:37 pm
i know they do that the ae111's but do YOU own an ae101? they also rev 500 rpm lower which lowers their top speed in each gear. so meh. who cares
my point being, he could probbaly drop it down 1-2 gears and still be able to keep the engine alive >.>
CozmoNz
Postby AceSniper » Mon Jan 31, 2005 10:33 am
Dont forget 91-91 20v's have the C52 with slightly longer ratio on two of the gears.
AceSniper
Postby CozmoNz » Mon Jan 31, 2005 2:50 pm
AceSniper wrote:Dont forget 91-91 20v's have the C52 with slightly longer ratio on two of the gears.
only 1 year :D
obviously you mean 91-94 :P. ae101. but i did not know that. what gears, and what speeds etc.
CozmoNz
Postby 10k 20v » Mon Jan 31, 2005 7:54 pm
only 1 year :D
when they ran c52's, yes, preface lift
3rd and 4th gear shifted closer to 2nd, 1st, 2nd, 5th same as c52
acesnipers is a facelift running a c56 so 160kph at 9000 for him
however mine has a c52
so in third at 8200rpm is 160 and 175-180kph at 9800 (rev limit on link set 10,000 and to busy at that speed to accuratly look at speedo while cornering)
you'll also find a 101 will limit higher than a blacktop, around 8300 for silvetop and 8000 for blacktop
**phones toyota to order trd gear set and final drive**
10k 20v
